CAGS eliminator install
Apr 6, 2005 | 02:03 PM
Does anyone have a good write-up on installing the popular CAGS eliminator?
Apr 6, 2005 | 02:11 PM
Apr 6, 2005 | 05:32 PM
Quote:
Originally Posted by SilverRoadster00
These are some good instructions. The install procedure is very easy. Get the rear of the car in the air (supported by jack stands), reach up on the driver side of the tranny and unplug the CAGS connector. Place the small cap from the eliminator on the transmission connector, then connect the larger piece of the eliminator to the wire that comes down from above. Use a zip tie to secure the wire and large part of the eliminator out of the way, lower the car, and you are on your way.
Apr 6, 2005 | 06:18 PM
Thank you guys. I will be doing this mod soon.
Apr 6, 2005 | 07:14 PM
Thanks, it sounds easy enough!
Apr 6, 2005 | 09:41 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
I will be doing this mod this weekend, thanks for the help
Apr 6, 2005 | 10:09 PM
From: Slower than a speeding bullet................ Fort Lauderdale, FL
Quote:
Apr 6, 2005 | 10:26 PM
Very easy to do and money well spent IMO
Apr 7, 2005 | 11:01 AM
Also, you could just go to Radio Shack, and pay $1 for a pack of 5 2.2kΩ Resisters. Plug the resister into the CAGS female connecter, and wrap w/ electrical tape. Done!!
Apr 7, 2005 | 11:04 AM
Bingo!
Apr 7, 2005 | 12:17 PM
Quote:
It took more time to jack up the car and crawl under it, than it did to install the CAGS eliminator.
Apr 7, 2005 | 12:34 PM
I just backed it up on Rhino Ramps and the whole process took less than 10 minutes.
