BSM removal.. thinking twice about it
How are they best taken off? Do I use a flathead screwdriver to pry them off? Rip them off with my teeth? And how about the sticky stuff holding them on - does it just rinse off?
I'd like to remove them without damaging the door. thanks.
http://grond.englandgreen.com/bsm
Take the strongest fishing line you can find, "saw" through the BSM and the door using a hairdryer to heat the adhesive backing. Take your time and don't be tempted to pull them off once you get some of it off.
How are they best taken off.........I'd like to remove them without damaging the door. thanks.
let it set in the sun till they're nice and warm, take a piece of 30# mono fishing line get behind and molding and start to "saw it off"..it's just held on with thin sticky 2 sided tape........ don't be tempted to grab the molding and pull!.... a little wd-40 sprayed on the top of the molding helps. when you're done, clean off the goo with wd-40, then wax, or maybe a little scratch remover then wax.
again, don't go to fast!!, take your time, gloves help with the fishing line..... i actually tied the line to 2 short (~5") wood rods.
no problem'o.
