For anyone interested I just installed the GHL Magnum Plus system and it is just what I was looking for. Nice low rumble, not too loud and way better than stock. Plus, I really like the look of those dual 4" pipes. Highly recommended.
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
C'mon guy! You must know by now that we need PICS!!
I like the sound but there instructions and packing suck, no gaskets, and they will not stay adjusted (I have To re-adjust them every 200 miles)
More Than Zero
I didn't even think to look for the instructions, but mine were very nicely packed. I had them installed as I didn't have the means to get the rear high enough. They snugged everything down tight and still had some movement. I had the shop do a tack weld on each side and they have been perfect since. Will be easy to grind away if I ever have to take them off. My car was nearly new, so used the original gaskets. Not sure if they came with any.
More Than Zero
Mine were packed great, much better than the Borla Stingers that I bought a couple of years ago and the gaskets were included. I didn't use the instructions since I had a muffler shop install them. They were installed a year ago and haven't been touched since. Still lined up perfectly!
