Oil consumption/ piston slap
Old Apr 7, 2005 | 06:24 PM
BIGSHOMIKE's Avatar
BIGSHOMIKE
Default Oil consumption/ piston slap
I have been looking searching this topic here and in the tech forum, its got me a little nervous as I look for a used C5.
Is this just a small percentage of cars, nothing to worry about? It looks as if all years might have/get piston slap?
I am no engine expert but guys I know who are into rebuilding them etc say thats more serious problem than dealers say it is.
Sorry if this is old news, this will be my first vette and I didnt realize these problems even existed until I was browsing through a Vette mag at the store the other day and came across an article on pulling the motor to replace rings, so I started looking around for more info.
Is there a way to protect oneself on a used one, or am I "rolling the dice" so to speak?
Old Apr 7, 2005 | 06:42 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Seen this yet?
www.pistonslap.com
Old Apr 7, 2005 | 06:58 PM
BIGSHOMIKE's Avatar
BIGSHOMIKE
Yes I read alot of it while searching around. I cant get the "winning arbitration" to pull up.
Do you know what the final decision was on the " piston slap" problem?
Old Apr 10, 2005 | 07:22 AM
koolvette01's Avatar
koolvette01
Default koolvetteo1
I too have read about the piston problem and was told that the oil consumption was normal. this was doing itn when I bought the car with 15,000miles on it and was still under warranty, I notice it when above 3200 rpm,s the rear panel is covered in oil flec,s and If it needs it and engine remove.l wow, how much and who is qualified to do this? is G m. going to help? this is obviously an on going problem from the factory
Old Apr 10, 2005 | 09:12 AM
Tino's Avatar
Tino
I have seen on previous posts where members have said that this effects early 01 production vehicles and effects Ls1 and Ls6 engines. Not sure how accurate this is, just stated what I have heard. I also heard that the GM repair is to replace the rings but I don't believe they bore, etc. I have an 04 and I don't get the piston slap or the oil flecks/consumption. In either case I hope your situation gets sorted out.
Tino
Old Apr 13, 2005 | 06:27 PM
koolvette01
Default koolvette01
Iam going to call the dealership and ask them, I will probably get a line of s@#$ then I'l try g.m. zone rep. wish me luck, any one heard of the cost or who is qualified to do this. Iwas thinking just to have the car sent to one of these rebuild places to up the horse power, they probably know more about them g.m.
Old Apr 13, 2005 | 07:12 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Well one way of checking a car out is to make sure when it's started that it's a cold engine before they start it. If it's been warmed up before you get there it probably has piston slap. Good luck with the search.
Old Apr 13, 2005 | 08:48 PM
Dave68's Avatar
Dave68
Some piston slap seems to be common among C5s that use the stock AC Delco oil filter. I use a K&N oil filter and have little to no slap. The filter is the key, at least in my case.
Old Apr 13, 2005 | 08:57 PM
D C's Avatar
D C
USMC (retired)
I am on an oil consumption test right now. I was told to bring it in 3 times...every one thousand miles (this was after the oil change). The first 1000 it was a 1/2 qt low and the second 1000 miles it was also 1/2 qt low. I was told by the stealership that it was normal or a they full of . Do I have a problem or is this normal consumption? How can you tell if there is a piston slap problem?
Last edited by snakeiz919; Apr 13, 2005 at 09:05 PM. Reason: only 1/2 qt low not a full qt at each 1000 miles
Old Apr 13, 2005 | 09:04 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I find it hard to believe that changing the oil filter can fix the problem. I heard it was in part the oil ring in the oil pump. I changed that out for the "new " one when I had the cam installed, and I still have some slap.
Ill have to try the oil filter myth next
Old Apr 13, 2005 | 10:26 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
I havent had any of the problems you guys have stated . I wish y'all luck getting it resolved
Old Apr 13, 2005 | 11:22 PM
Dave68's Avatar
Dave68
I, too was a misbeliever until I changed filters. Either my hearing has taken a sudden turn for the worse, or that cold start ticking has quieted down significantly. The K&N and Baldwin filters do flow much better than many others. Their filtering ability is very good (from what I've read) as well. Give it a shot; hey, it's only $10.
Old Apr 15, 2005 | 04:03 PM
koolvette01
Default koolvette01
haven't driven car in 2 weeks, going to start it in the morning. isn getting down to 40 here in carolina, am going to try and extend the warranty for 1400 bucks , but it has to go thru an inspection. look for oil flecks after the car has warmed up, you dont have to rev to high ,just passing gear then look at your rear quarter panel.
To Oil consumption/ piston slap
