climate control
Old Apr 7, 2005 | 09:23 PM
prt98's Avatar
prt98
Default climate control
I am having a problem with the climate control on my 98. I cannot change the temperature setting. If I turn the **** and wait for it to show the outside temp again I can adjust it one degree. Anyone had this problem?
Old Apr 7, 2005 | 11:39 PM
rickko's Avatar
rickko
Check your codes against this link:
http://www.dustingarner.com/diccodes.htm
..rickko..
Old Apr 8, 2005 | 12:01 AM
coast7's Avatar
coast7
You may want to check your interior temp. sensor. It is located on the dash to the right of the ignition. Do a search for the CLB installation and you will see a picture of it (it must be removed during installation). It is very easy to get to...the sensor must be inserted properly into the sleeve for it to operate correctly.
Old Apr 8, 2005 | 08:25 PM
prt98's Avatar
prt98
what is the CLB?
Old Apr 9, 2005 | 11:34 AM
kenrobb's Avatar
kenrobb
Had the exact same problem with my 99 3 times. It was a somewhat common problem back then. It needs replacing to fix. Problem is that you have shorted the unit out with an ESD (electrostatic discharge). I did this on mine as I said 3 times before GM replaced the unit under warrenty with a 2001 model unit. The new unit has a grounding plate behind the adjusting **** to take any static charge on your fingers to ground. You can get a used unit from several people on the parts section ( karshop@tampabay.rr.com ).
To climate control
