Speaker Vibration
dont try to take off the speaker screen without removing the door panel--just folded over metal tabs holding it down
Before you remove the door panel, check the Bose insignia...it may be loose and it vibrates. I reglued both of mine...no more vibration with base
I had the same problem with my Bose logo. A little RTV silicone will take care of that.Paul
Had the same problem with mine, it really BLOSE.I'm performing it now.
Link here> http://www.corvetteactioncenter.com/....php?qstId=276
3 M does not make the foam tape any more but I found an alternate tape at Lowes >Frost King Foam Tape 3/4"wide X 5/16"thick X 10' Long (need 2 rolles)
1 roll duct tape
self adhiesive Felt pad called [Stick-it-Felt] can be purchased at Michaels craft store. Need 2 sheets 9"X12"
Depending on model year, you wil also need a few parts, review SB! In my case for a 1999 I needed all the parts listed ($50.00 bucks total from a forum vendor)!
Cranke up the tunes!
E-mail to 3M
----- Original Message -----
To: kevinsmonticello@msn.com
Sent: Thursday, April 07, 2005 2:38 PM
Subject: Re: Foam Tape Question #USLN-6B8PUU
Dear Kevin,
Thank you for your inquiry regarding the Cat# 02286 3M Interior Foam Tape
Weather Strip. We appreciate hearing from you unfortunately the Weather
Strip you are in search of has been discontinued without replacement.
You may wish to consider continuing your search through the Thomas Register
@ www.thomasregister pertaining to other manufacturer product
possibilities.
Your interest in and use of 3M products is appreciated.
Best Regards,
Ron
Construction & Home Improvement Markets Division
800-537-9514
www.3m.com
-----------Original Message Follows------------
Subject = Foam Tape Question
Message = Hello,
GM Issued an SB Number: 01-08-64-009A, Subject: Door Rattle with Moderate
to
High Audio System Volume, Model Year: 1997-2002 Chevrolet Corvette.
This SB requires the use of 3M Open Cell Interior Foam Tape P/N
051131-62385
and Velcro®, 3M® P/N 051131-06481.
I've searched the Web for these P/N's and got no hits.
Can you please provide the new P/N's that are equivalent? And can you point
me
in the right direction as to where I can buy these items in Michigan?
Link to the SB
Thanks in advance,
Kevin
