GM Bra Install
Old Apr 8, 2005 | 09:26 AM
SilverRoadster00's Avatar
SilverRoadster00
Default GM Bra Install
I tried a search, but couldn't find the link to the "good" instructions for installing the GM bra, anyone have it handy?
Old Apr 8, 2005 | 09:37 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Tech tips......
https://www.corvetteforum.com/techti...D=32&TopicID=1
Old Apr 8, 2005 | 09:44 AM
SilverRoadster00
thanks, that's exactly what I was looking for.
Old Apr 8, 2005 | 09:45 AM
MELVINJ's Avatar
MELVINJ
I got the gm bra for my 2004 coupe. But found the snaps on the wheel wheels ARE NOT CORRECT. If fact, I returned it to the dealer, and the one I got after that was the same way. This is an easy fix, but will confuse you, as as it comes, will NOT snap correctly to the wheel wheels
PM me. The fix cost about $3, and I can send you the info. Before you email me, try installing it first, so you see what I am saying
Old Apr 8, 2005 | 10:05 AM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
I had a GM bra and it went on without any problems. I am not sure what you mean. I can say the directions you get with it are worthless.
Old Apr 8, 2005 | 10:06 AM
SilverRoadster00
PM sent. Are you seriously going to make me try the install before enlightening me??
Mr. Wonderful, how bad were the rubber grommets behind the wheel wells?
Old Apr 8, 2005 | 12:08 PM
DonWarren's Avatar
DonWarren
I have the GM Bra, Got the wrong screws as mentioned earlier...What is the fix? does Home depot have these screws with the snaps???
Old Apr 8, 2005 | 12:22 PM
PepFontana's Avatar
PepFontana
Old Apr 8, 2005 | 12:45 PM
I agree the directions are not very clear. The only snaps I had problems with were the ones in the wheel wells. The little rubber grommets that came with the bra are basically worthless. I ditched them and ended up just putting a lock washer and nut on the snap screw from the inside of the wheel well liner. Has remained tight for better than 3 years. You can also buy some marine snaps to replace the supplied GM snaps.
To GM Bra Install
