[Z06] Noises ????
Old Apr 8, 2005 | 09:38 AM
Green Hornet 2's Avatar
Green Hornet 2
Default Noises ????
When I'm in a quiet area, like a parking lot, and I push the clutch in and "coast" I hear a chattering or grinding sound.
I also get a clicking sound from time to time, again when going slow, this comes when I give it gas and then let up on the pedal.
Just thought I would ask around to see if any one of you would know something.
You know what happens when you go to the dealer, they always tell you that's the way it is supposed to sound, etc....
Old Apr 8, 2005 | 10:49 AM
SoulDad570's Avatar
SoulDad570
Try doing the same test while putting the transmission in neutral and pressing the clutch. That will cause the drive shaft and gears in the transaxle to stop turning. If it's still making "funny noises" it's probably not drive train related. Maybe a wheel bearing or something like that..
Also, try to isolate the location of the noises, front? rear? console area?
Note that Z06's have very minimal sound insulation (in order to keep weight down), so you hear pretty much every noise that every system makes. That's OK as far as I am concerned, but it does annoy some folks.
Old Apr 8, 2005 | 11:53 AM
procharged_z06's Avatar
procharged_z06
Does It Sound Like Lifter Noise ? Mine Has The Same If So
Old Apr 8, 2005 | 01:28 PM
KMeloney's Avatar
KMeloney
Documented (here, at least) "common" noises tend to be:
- "marbles in a can" noise when shutting off car (can be avoided by pushing in the clutch during shut-off)
- "ticking" or "tapping" from lifters
- "whistle" from lifters/intake
- "exhaust jingle" (from exhaust hanger springs clanking against exhaust -- can be fixed with TSB)
If it's one of these sounds, then you're not alone. Many people experience these noises. So, yes, they're "common," but I don't like the dealers' word "normal." "Normal" suggests that they're ok -- but the noises really bother some folks. I, along with many others, have simply chalked these noises (with the exception of the exhaust jingle) up to the nature of the beast, as these cars are more like race cars than cruising sedans.
-Kirk
Old Apr 8, 2005 | 10:15 PM
Green Hornet 2
Thanks, it helps to hear it from someone else.
Everytime I hear a new noise I think something is broken.
I agree with you about the dealer's word "normal".
Old Apr 8, 2005 | 10:36 PM
Marine's Avatar
Marine
-Kirk
You forgot
- "AAAAAAHHHHHHHHHHHH" from passenger side when shifting into 2nd and 3rd
To Noises ????
