headlight help??
Old Apr 8, 2005 | 02:40 PM
rockrz's Avatar
rockrz
Default headlight help??
Okay guys....UPS just delivered a replacement headlight assembly from Gene at Karshop, so I won't have to continue driving a one-eyed vert. I'm gonna install this puppy when I get home after work, but my time will be limited.
So....is this an easy-out, easy-in replacement type thing or will it take a while? It is the entire assembly with motor, bulbs, door, bezel, etc.
If you have any helpful hints or advice, lay it on me baby!!
Jerry
Old Apr 8, 2005 | 02:42 PM
Antvette's Avatar
Antvette
Veteran: Marine Corps
I replaced mine in about 5 minutes, if that. But, the front bumper was removed for me. It's not hard. There is a total of 5 screws and a plug. That's all.
Old Apr 9, 2005 | 11:49 PM
DeeGee's Avatar
DeeGee
This article explains how to fit euro headlights. You can see from the removal procedure how to remove (and by definition refit) the stock lights.
http://www.c5forum.com/diy/eurolights.php
Courtesy of Redshift
Old Apr 10, 2005 | 12:01 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I think he's replacing the whole assy.
To headlight help??
