Fuel injector upgrade
Old Apr 15, 2005 | 11:40 PM
vetred's Avatar
vetred
Thanks, really, this IS good stuff done very well !
Old Dec 6, 2010 | 01:37 PM
Techsan's Avatar
Techsan
Just posting to this thread so I can find it again when I do my injectors.
Old May 23, 2017 | 03:05 AM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Just kicking this great 8 year old thread.. I removed the injectors on my 98 tonight. They are original (80K miles), and I've had 2 become leaky over the past few months. A few extra bits of helpful info:
- To drain as much gas as possible out of the rail, I started the motor and pulled the fuel pump fuse. Motor runs about 5 seconds and dies.. Even doing this there is still A LOT of fuel in the rail - I would guess 1/2 cup or so. Beware of that in all steps.
- Like the sparkplugs, getting the lead off injector #7 is tuff! After wrestling on it for about 10 minutes, I decided to unbolt the rail first. Once I could nudge it forward a bit, the lead came off very easy. Take care not to loose the little blue seals in the electrical plug - I had one fly out.
- I was able to buy a fuel line tool (as shown above) at Autozone for $9.
- It was a breezy 1 hour project to get the injectors off. Not bad at all.
After browsing new injectors (prices range from $40 up to $150 per injector) and reading up, I decided to send my old injectors off to a shop that will clean and test them... for $11 each. I feel like it's better to have refurbed original injectors than new cheap ones... I'll report back when my injectors come back from the shop and I get them installed.
Fred
Old Jun 2, 2017 | 03:46 PM
SDVette's Avatar
SDVette
Injectors came back.. tested (with test results) and new o-rings and micro-filters (old ones returned). Installed them in the car today and everything is running fine.
The only tweak to the re-assembly instructions at the top would be: Connect the wires to the rear injectors BEFORE you seat the rail assembly.. Much easier to attach the connectors with more room to work.
Old Apr 18, 2020 | 01:36 AM
tcallebaut1's Avatar
tcallebaut1
Cruising
Default Fuel injectors
Thank you for the great information on fuel injectors replacement Your post is still working.
Thanks again
