Help!!!!!!!
Old Apr 10, 2005 | 08:58 PM
2002magred's Avatar
2002magred
Default Help!!!!!!!
I know we have had a lot of talk about lowered cars. But I need some help. The other day my CCW's 505a's come in. Also I got the brake kit from Daemon Motorsport/ Stop Tech. I installed the brake kit with no problems. I cut the bushings in the rear and turn the bolts in the front to lower the car. This is where my problem begins. The tires on the CCW"s are 305-30-19 rear 275-30-19 front. After I put her on the ground, the left side front and rear is to high. After putting in two bushings back in the rear and adjusting the bolts 4 or 5 times. I get the rear to 27 and half inches off the ground from the fender well. My problem is the front is to high. With the bolts all the way in. The L/F is 27 1/2 inches and the R/F is 27 11/16 inches. When I adjust the L/F to raise it the same height to the R/F they are both moving up. The right very little. Right now I turned the L/F 2 1/2 turns clockwise to bring it up. L/F is now 27 1/2 inches and R/F is 27 3/4 inches. If I turn the L/F up I will be above 28 inches. How many of have you cut the front bushings. I couldn't find any instuctions on this. Sorry this is so long. I would be gratefull for any help.
Old Apr 10, 2005 | 09:00 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Drive your car for about 100 miles - it will settle and then make your final adjustment and get a 4 wheel alignment.
EG
Old Apr 10, 2005 | 09:05 PM
army2000's Avatar
army2000
St. Jude Donor '11
Holy Tortillas. Man, that's why I have not screwed around with the height of my car. I don't care if it looks like a Jeep Grand Cherokee. Good luck with that.
Old Apr 10, 2005 | 09:29 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
It will settle. You should wait until it settles and then try and adjust it from there...
Peace
Willfulone
__________________
..................Click for
Old Apr 10, 2005 | 09:32 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
EG
Old Apr 10, 2005 | 09:34 PM
blazeone's Avatar
blazeone
Don't sweat it. Like the others said drive it and let it settle. For all you "stock height car" guys/gals they are not perfect from the factory either.
Old Apr 10, 2005 | 09:36 PM
BeastieBoys21's Avatar
BeastieBoys21
cant wait to drop mine....
Old Apr 11, 2005 | 12:07 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Yep! Let it settle. I was scared to death after "lowering" mine. It looked like a 4x4 but everyone told me to go drive it around for a half hour (luckily it was dark). When I came back, it looked great. After a week or so, it got even better.
Just make sure that you've turned all the bolts the same amount, regardless of how it looks after being up in the air. When it settles, you should be pretty close.
Old Apr 11, 2005 | 12:18 AM
F1_SS's Avatar
F1_SS
I just got mine lowered today, and i didnt even measure it, i just like the look from afar, But yes, let it settle.
Old Apr 11, 2005 | 12:19 AM
MY1STPEWTER's Avatar
MY1STPEWTER
I drove mine 2 or 3 days before making final adjustment. I only ended up adjusting the rear. I have 1 thread showing on one side and 3 threads on the other.
To Help!!!!!!!
