LED Mods
3mm LED's (Super Bright) and 1/4 watt, 430 ohm resistors (Door switches, DIC controls, T/C switch and Ride Cntrl.
I hope someone else will chime in on the HVAC and Radio
Good luck
Dave Q.
driver door switch 4 leds (5mm)
passanger switch 2 leds (5mm)
tacktion buton 2 leds (5mm)
left gauge cluster 4 leds (5mm)
right gauge cluster 3 leds (5mm)
trunk button 1 0r 2 leds (5mm)
rear view mirror depending on miror 12 leds (5mM) or 2 bulbs with leds in them.
as far as the foot wells and trunk and tail lights you can buy plug and play leds, bulb is 194 from
(3mm)autoalumation
radio 10 (5mm) 1
you can substitute the 5mm for 3mm if you want they fit a little better in the sockets.
Illmac thanks for the list.
With the left side of the DIC, you have to use 3mm to make them fit, or you will be shaving off LOTS of plastic like LV 2 XLR8 said...
As for the interior stuff, this count below is right. Just make sure you get extra just in case. (I used 5mm LED's in my HVAC though)
(3mm)autoalumation
radio 10 (5mm) 1
Good luck!
(3mm)autoalumation
radio 10 (5mm) 1
In addition, for the left DIC switches, use 3mm LEDs, those are the smallest bulbs I have ever seen and even 3mm have to be trimmed.
Just did the same replacement (thanks to Spdklz and CULookin; I probably drove both of them crazy with emails
), and found the left DIC to be a lot brighter than the right DIC. I will be going in there this weekend and painting the sanded down tips of the left LEDs black to help equalize the brightness to match the right DIC.I'm also going to add a 6K ohm resistor into the backlight power feed of the HVAC unit to dim down the HVAC to have the approximate same illumination as the radio (thank you LV_2_XLR8 for helping me with this item
). (I'm adding the resistor rather than go into the HVAC box...something I will never do again.
) The HVAC and left DIC are bright even during the daytime, while the right DIC and radio (along with all the switches) are great at night, but can't be seen in daylight. Also, for anyone interested, if you should lose or like I did, break one of those plastic holders in the DIC switches, the part numbers are:
left DIC (small ones) 12198644, right DIC (larger ones) 16056613. This includes the bulb and the plastic holder. I suggest ordering from Bob at Fichtner or GM Parts direct since my local stealership really put it to me on this little bulbs.
wow just looked up the price on gmparts direct, and those little baby are expensive, $1.60 (small) and $3.27 (large)
WhiteC5Vette, I know you sent me instruction on how to disassemble the mirror - but has anyone actually completed this mod??
That's the only light I want to change real bad - to Evil Red
EG
EG
Hey man, shoot me a PM when you get this done... My HVAC is still sitting on my kitchen table waiting for your results! Thanks!
)When I did the single resistor thing, I ended up using two 12 watt, wire wound resistors in series, in order to get the resistor to be cool enough to touch. (1/4 watt resistors come with the LEDs) And the 12 watters still get pretty hot. These little suckers really draw some amperage. (the ten I used in the radio drew 1/2 an amp total!) if you use more in the HVAC the amperage will only go up. Be sure you test the unit with power on it for a while before you reinstall it in the car. Keep checking the temperature of that resistor. If it gets too hot, it will fail and could cause a fire in a spot not easily extinguished.
Let us know how you do.
Thats too much work for me. I guess I'll just deal with the dingy white.
