Tire sensor washer??
Old Apr 14, 2005 | 04:11 PM
jwa95ta's Avatar
jwa95ta
Default Tire sensor washer??
We bought new wheels for the vette and I had the tires taken off last saturday and the TPM out. Before I took the wheels to the tire place I let the air out and dropped the TPM into the tires. I didnt notice any washers on the TPMs. I removed the nut on the TPM and all I remember seeing was a o ring. But on a post I saw for a dealership selling TPMs, part of the package had washers for the TPMs as well as o-rings.
this is the post I read
Just wanted to make sure I didnt loose something. I have the new wheels now and was going to put the TPM back on them and have the tires mounted.
Thanks,
Jason
Old Apr 14, 2005 | 04:18 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Your on the right track, the 97-00 sensors' "washer" IS an o-ring. On the 01-04 it is a t-type o-ring good luck 2001-2004 Sensors
25773946 - sensor – 54.77 each
15125473 - nuts – 2.45 each
Total setup is 228.88 + 15.50 shipping
97-2000 Sensors
10438853 - sensor – 84.40 each
10268439 - nut – 1.25 each (5 pack)
10268438 - washer – 1.25 each (5 pack)
Total setup is 350.10 + 15.50 shipping
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
on the older style (97 - 00) the sensor has an o ring on it, then I think they have also came out with an o ring that goes on the outside under the nut due to problems, but maybe I'm wrong. On the newer style I believe the o ring is part of the sensor.
Old Apr 14, 2005 | 05:22 PM
Old Apr 14, 2005 | 06:42 PM
jwa95ta's Avatar
jwa95ta
Sweet guys, thanks a lot for the replys. Guess if I read that one post close enough I would realize that was the o-ring/washer deal.
CF rocks!!
Jason
Old Apr 14, 2005 | 10:18 PM
66427-450's Avatar
66427-450
Originally Posted by ptdrummer54
on the older style (97 - 00) the sensor has an o ring on it, then I think they have also came out with an o ring that goes on the outside under the nut due to problems, but maybe I'm wrong. .....
i think that's correct. sensor has an o-ring on/in it, then you put another on from the outside, under the nut.
To Tire sensor washer??
