Any negative effects when using sound deadeners?
Old Apr 15, 2005 | 12:02 PM
ColdSmoke's Avatar
ColdSmoke
Default Any negative effects when using sound deadeners?
Has anyone had any negative effects after installing Dynamat or BQuiet Utltimate? Does it affect the Tire Pressure Monitoring function in a bad way? Anything else?
Old Apr 15, 2005 | 12:04 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
none that I've read..
Old Apr 15, 2005 | 12:14 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I used Dynamat Xtreme and have had no issues. The only difference is the original DM had to be heated before it was applied and sometimes had a tar smell when it got hot. DM Xtreme is peel and stick, also no smell when it's hot. Hope this helps.
BTW, I've done the WHOLE interior as well as, wheel wells and undercarriage.
Old Apr 15, 2005 | 12:48 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
To install it you have to strip out the interior. If you are questioning any potential impact to the TPS because of vertte's post, it may just be that a conection was not made during the close up of the installation - it is not a problem with the soundproofing...
Old Apr 15, 2005 | 12:49 PM
YELLOHHH's Avatar
YELLOHHH
Only weight, if that's an issue for you.
Old Apr 15, 2005 | 01:01 PM
ColdSmoke's Avatar
ColdSmoke
Thanks guys.
The car interior is stripped, cleaned and ready to go.
I pulled the passenger side door off but except for that rubber seal, it looks like it may not have room for the Ultimate. Did anyone do their doors?
Old Apr 15, 2005 | 01:20 PM
andy82's Avatar
andy82
2017 C7 of Year Finalist
Old Apr 15, 2005 | 01:31 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Thanks guys.
Yes, I did inside and outside my doors with Dynamat Extreme
Old Apr 15, 2005 | 01:58 PM
66427-450's Avatar
66427-450
To each their own.........
Let’s see: no increase in performance, it cost $, significant installation time, odds are you won't recover investment when it's time to sell it (it actually could be a determent, I know it would be if I were the buyer)..... Nope, not my style at all. To me adding weight for something like that is almost sinful
But that's just one perspective
Old Apr 15, 2005 | 02:48 PM
0EG@EnglandGreen
Supporting Tuner
I would guess that you do not have an aftermarket stereo, you never drive your Vette crosscountry and you no longer have stock run flat tyres.
If any of the above is a yes, the Frost King/Dynamat Extreme mod would be worth it's weight in saffron.
Night and day difference between stock and sound insulated.
2 cents deposited.
EG
Old Apr 15, 2005 | 02:51 PM
scott_fx's Avatar
scott_fx
you rarely recover any investment in a car. If it makes your ride a bit more enjoyable then it's worth it.
Old Apr 15, 2005 | 03:32 PM
ColdSmoke's Avatar
ColdSmoke
Additional weight will be a disadvantage to some. A less noisy ride won't matter to some. I feel differently. I do not race the car and therefore feel that an additional 20-30 pounds is a small price to pay for an enjoyable ride. The sound-deadening project will be completed today. The EMTs are being replaced on Tuesday. If these two changes don't improve the noise and ride, I will sell the car. The roads around here getting so bad that I no longer enjoy driving the car. I hope all this time and expense is worth it.
Old Apr 15, 2005 | 04:25 PM
0EG@EnglandGreen
Supporting Tuner
Do not forget to stuff the wheel wells!!!
EG
Old Apr 15, 2005 | 04:26 PM
66427-450's Avatar
66427-450
- factory stereo,
- never drive x-country (i fly)
- tires; GY EMT's and KD's here (depending on use)
we each value different features/atributes of our c-5's...... and that's cool. we all have fav color & option combos, a car i'd never buy may be your dream, and the other way around
Old Apr 15, 2005 | 04:27 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
I just did the hatch area with Frost King and it smells a little funky...
I am hoping that fades with time.
Old Apr 15, 2005 | 05:03 PM
djengr's Avatar
djengr
I did the FK about 2 months ago, smell goes away.
Old Apr 15, 2005 | 05:15 PM
Mike Mercury's Avatar
Mike Mercury
you're right, we're different. My Vette is for driving enjoyment. I never worry about the the "recovery cost" of a mod.
if a mod improves the enjoyment of a car... what difference does it make if you don't recover the mods cost during resale (within reason... of course)
Relax; put the calculator down, and enjoy driving your Corvette
To Any negative effects when using sound deadeners?
Old Apr 15, 2005 | 05:34 PM
CUlookin's Avatar
CUlookin
weight... that's about it!
Old Apr 15, 2005 | 06:11 PM
99FRCWhite's Avatar
99FRCWhite
Since you guys are on the subject. How much DynoMat Extreme does it take to do the car and where is the best place to buy. I am iterested in hooking up my 99FRC with the stuff.
Old Apr 15, 2005 | 06:32 PM
LoneStarFRC's Avatar
LoneStarFRC
Nope. Works for me.
