Rear Hatch Release
Old Apr 18, 2005 | 04:07 PM
BlackArrow's Avatar
BlackArrow
Default Rear Hatch Release
Took my top off for the first time.........the rear latch was very hard to release. I had to push with both hands in order to release it. Is this normal? Does it need adjustment?
Old Apr 18, 2005 | 04:10 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
my glass top takes more effort to release the rear latch.. it will loosen with use..
Old Apr 18, 2005 | 04:19 PM
ClovisFox's Avatar
ClovisFox
Make sure that you first press the safety latch at the base of the rear latch handle before pulling the rear latch. Mine works fine once I press the latch.
Old Apr 18, 2005 | 04:53 PM
BlackArrow's Avatar
BlackArrow
Thanks, I did.....it still takes a lot of force to pop it.
Old Apr 18, 2005 | 05:10 PM
The release for the rear latch on the top should not be that difficult to pop. I always release the front two latches first, then push the button on the rear latch. Very little effort required.
To Rear Hatch Release
