How do I know what gears I have?
A4 could get either:
2.73
3.15
MN6
Has no option, if it is a MN6 it is always:
3.42
And yes, the higher the number, the lower the gear ratio and the faster you will accelarate due to mechanical advantage. The lower gear ratio (higher number) will limit your top speed.
http://mikemercury.home.att.net/342.htm
Motive Gear makes gear sets in the 3.73, 3.90, and 4.10 ratios. These gears would need to be installed into an existing rear carrier (obviously the original gears would be removed first).
The one buying the 3.73 already has a Predator and will use it to reprogram the computer after the gears are installed.
The other is buying a used Predator from a different guy here on the Forum.
I guess my thoughts are what your are plans for the car? Normal street driving, you'll see more "SNAP" off the line. I think we all tend to fall into the trap of wanting a car that will melt the tires off of it like a Top Fuel Rail.
Personally - I have an MN6 with 3.42's and I can tell you that I've turned the TC off once, slipped the clutch, and smoked the tires. (closed access off public roads of course!
) I know it can do it - been there, done that. Guess I'm an old fart and I don't get my jolly's melting $300 tires...... .02 deposited.....
Enjoy your car and don't worry too much about getting rubber in all four gears, like the song says!
