How do I know what gears I have?
Old Apr 20, 2005 | 01:12 PM
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
Default How do I know what gears I have?
02- C5 - A4, wondering what gears I have or how I can find out?
Old Apr 20, 2005 | 01:15 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
check the RPO codes on your glove compartment door, assuming they have not been upgraded they'll be on the list
Old Apr 20, 2005 | 01:23 PM
ORANGEBROTHERS
I did but how do I know which code pertains to the gears and or size? I see a lot of numbers and letters but nothing that identifies the gear size? Thanks...
Old Apr 20, 2005 | 01:28 PM
JoshVette's Avatar
JoshVette
If you look in the glove box, look for a "G92" that's the 3.15 with performance axle.......just like mine.
Otherwise, just climb under the butt of your car and look at it. It will tell you what gears on the gear box.
Old Apr 20, 2005 | 01:29 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
AAB
Memory Package (Req. CJ2)
150
AG1
Power 6-Way Driver Seat ( Standard on Z06) 305
AN4 Child Seat Tether NA
AP9 Parcel Net (Coupe Only) 15
B34
Floor Mats
25
B84
Body Side Moldings
75
CC3
Removable Roof Panel Blue Tint
650
After
9-14-00
750.00
C2L
Dual Removable Roof Panels
1100
After
9-14-00
1200.00
CV3
Mexico Export
0
DD0 Electronic Monochromatic Mirrors 120
EXP
Export Option
TBA
FE1
Base Suspension
FE3
Sport Suspension (Included With Z51)
FE9
Federal Emissions
0
F45
Selective Real Time Damping, Electronic (Not Avail w/Z06)
1695
G92
Performance Axle Ratio 3.15:1 MXO Auto (Not Avail w/Z06)
300
GU2
Std. Axle Ratio 2.73:1 MXO Auto -
GU6
Std. Axle Ratio 3.42:1 Six Speed -
LS1
Std. 5.7 Liter SFI Aluminum V8
0
MN6
Six Speed Manual Transmission (w/1YY37- $0)
815
MX0
M30-Automatic Transmission - Includes G92 Performance Axle Ratio
0
NB8 CA/Northeast Emission Override 0
NC7 Federal Emissions Override 0
NG1
Massachusetts/New York Emissions Requirements
0
N37
Steering Column; Power Telescope Manual Tilt 350
N73
Sport Magnesium Wheels (Not Avail w/Z06) 2000
R8C
Customer Pickup at The NCM Click on Option Number
490.00
R6M New Jersey Surcharge (mandatory in NJ) 0
QD4
Domestic Standard Five Spoke Wheel -
QF5
Deluxe High Polish Wheel (Not Avail w/Z06) 895
After
9-14-00
1200.00
UN0
Stereo System Delco-Bose with CD
100
U1S
Remote Compact Disk Changer (All Models)
600
V49
Front License Plate Frame
15
XGG
Front Tire - P245/45ZR17 BW SBR
YGH
Rear Tire - P275/40ZR18 BW SBR
YF5
California Emissions -
Z49
Canadian Options
Z51
Performance Handling Package:
Larger Diameter Sway Bars Than Previous Years
(Included With FE3 Sports Suspension, includes power steering fluid cooler) Not available with F45 or on Z06
350
Old Apr 20, 2005 | 01:35 PM
ORANGEBROTHERS
Cool thanks, let me go outside and check it out. Got my fingers crossed cause I really want those 3.15's. Back soon...
Old Apr 20, 2005 | 01:38 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
In addition to checking the RPO codes, you can do it easily on an A4 while driving. Put your gear selector in 3rd, accelerate to 75 mph and hold it there. If the tachometer shows 2730 rpm you have 2.73 gears. If the tach shows 3150 your gears will be 3.15 and so on. This is actually better than the RPO codes because the previous owner may have changed the gears and your RPO code would then be useless. It also is easier than jacking up the car and crawling under it to check the gearbox.
Old Apr 20, 2005 | 01:42 PM
ORANGEBROTHERS
Bummer! Got 2.73 Code shows GU2.
Old Apr 20, 2005 | 01:45 PM
ORANGEBROTHERS
How does it run with the 3.15's? Is it much faster than the standard 2.73 cars?
Old Apr 20, 2005 | 01:48 PM
lvvette777's Avatar
lvvette777
Don't be bummed, you were driving the car and were happy with it until you knew the gear ratio right? Now what if the 3.15 code was in the glove box, would you feel better? The car isn't going to perform any differently now that you know the gear ratio right?
Don't let a number get you down, if you liked the car before there is no reason not to like it now.
Old Apr 20, 2005 | 01:51 PM
ORANGEBROTHERS
Hey thats true still love the car. Great point! Thanks
Old Apr 20, 2005 | 01:54 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Old Apr 20, 2005 | 01:55 PM
3RD-INF's Avatar
3RD-INF
I wouldn't let that bother me. I have the 2.73 and it works great. A little slow off the line, but top end is wonderful. If you do a lot of highway driving, you'll see what I mean.
Old Apr 20, 2005 | 02:14 PM
JoshVette's Avatar
JoshVette
What's you best 1/4 times??
Really depends on the driver if you're talking about a race at the track....if you and I were exactly equal drivers, I'd probably pull away from you a few car lengths, but not much i'd imagine.
I can spin the tires at will off the line, even on dry pavement, no biggie.
I think the 3.15's are maybe just a few tenth faster in the 1/4.
I'm right at 13.4 1/4 bone stock, in drive, no burnout, nonrunflats, but not the best driver and don't do it enough to know how.
I get 27-29mpg on the highway at cruising speed of 67-70mph.
I love my vette.
Old Apr 20, 2005 | 02:26 PM
ORANGEBROTHERS
I love my vette.
Haven’t had chance to take it to the track. I’m guessing that the car is bone stock though.
Old Apr 20, 2005 | 05:34 PM
Time for an upgrade.
Old Apr 20, 2005 | 05:42 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Spoken like a man with a true 2.73 ratio,
I've got a 3.15 and don't thinks it's enough, I can't imagine what a 2.73 feels like ..
Oh well at least the car looks nice and fast.
To How do I know what gears I have?
Old Apr 22, 2005 | 02:40 AM
trueblue02's Avatar
trueblue02
Put a vararam on and it will make up most of the difference. Mine is going 12.9 on the 1/4 mile.
Old Apr 22, 2005 | 04:11 AM
Venos's Avatar
Venos
3.42 gets no love! They're a great compromise.
Old Apr 22, 2005 | 05:00 AM
JadeDragon's Avatar
JadeDragon
Great question, DJN! I just got my '97 C5-A4 last weekend and was wondering the same thing. Although I assume if it has the upgraded ratios that would have been a selling point mentioned by the dealer. So Im assuming I have the 2.73. Im gonna check for sure tomorrow.
The car is still incredibly powerful though! Way faster than my twin turbo 300ZX.
How hard and expensive of an ordeal is it to upgrade such a thing?
TrueBlue02 mentions a vararam. Ive heard this mentioned before, but not sure what that is. Is that step #1 to modifying a stock A-4 for more HP and quicker bursts of speed?
OK I ADMIT IT! Im already wanting to pump up my beast to it's maximum potential!
Thanks!!!~~~JadeDragon (Patrick)
