Unseen Mods???
Old Apr 20, 2005 | 05:36 PM
1stTimeVette's Avatar
1stTimeVette
Default Unseen Mods???
Hey gang, I wanted to know what I could do as far as Mods to my 2004 CE Vert to improve the power, performance and handling w/o taking the car too far away from stock? If money were no object, but you wanted to keep the look and sound of the stock Vert, what would you all do?
Thanks for your input. I love this forum almost as much as I love my Corvette. I wish I had time to drive it more. Got it on Feb. 1, 2004 and only have 5,900 miles on it.
Old Apr 20, 2005 | 06:29 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Bilstein Sports shocks, Hotchkiss sways with heim joint end links, bump steer, Supermaxx headers with high flow cats through stock mufflers OR TTi, Blackwing, NAAAAAWS
Another way to go is C5-R 427 TTi through stock mufflers. Now that's a sleeper!!!
Old Apr 20, 2005 | 06:57 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
What he said ...
I added a 1/4" heat tunnel plate from Jeff @ Elite Engineering ... that things awesome for heat issues and improving the roll & body sway.
Old Apr 20, 2005 | 09:07 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Here is our mod list of the things you basicallyt can't see...but the car hauls azz.
o C5R-427 Racing Block
o Lunati Forged 4.00" stroke crank
o Lunati Billet 6.125" connecting rods
o Lunati custom pistons
o Lunati/Taylor moly file fit rings
o Lunati/King & GM bearings
o Modified LS6 oil pump
o Comp Cams adjustable timing set
o CNC Stage IV cylinder heads
o 240-244 114 XER Cam
o 42lb Holley injectors
o Fast-90mm Intake
o TPIS Throttle Body
o Throttle-Body Bypass
o BPP Vortex Ram Air
o BPP PowerDuct
o BeCool Radiator
o Coated StainlessWorks 1¾" Long-tube headers
o Whisper X-Pipe
o B&B PRT Quad Ovals
o Compression 11.5:1
o PCM re-program by Ed Wright at Fastchip & Mike Norris
o Random Tech High-Flow Cats
o Underdrive Pulley
o 160 Thermostat with Fan Controller
o FLP Stage V Racing Tranny
o B&M Tranny Supercooler
o Vigilante 3-Disc Torque Converter
o ZO6 3.42 rear
o Dilusi Stage III Racing Brakes
o QA1 12-point Adjustable Shocks
o Hotchkis Stabilizer Bars
o Lowered
Old Apr 20, 2005 | 09:16 PM
NSTG8R's Avatar
NSTG8R
i'm with them a 427 would be the ticket.
Old Apr 20, 2005 | 09:17 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Hey great car. For my $/02
I say Procharger and cold air intake. There is much more you could add to the list but for fast street, stock looking, that'll do.
Best of luck do whats right for you.
Old Apr 20, 2005 | 09:21 PM
0EG@EnglandGreen
Supporting Tuner
Sully,
Slightly off topic but.... I meant to ask you this before but I forgot. What are the DISadvantages of the underdrive pulley?
Lower alternator charge? Runs hotter (because water pump is turning slower)? A/C not as efficient? Power steering not as responsive?????
I am tempted to install one because I know all the benefits - but I was wondering about the negatives.
EG
p.s. I already have 160 Thermostat with Fan Controller as well as the TB bypass - and the High Performance Hood Seal
0EG@EnglandGreen
Supporting Tuner
Procharger whine will give the game away. Anyone with a brain will know it's not stock
Old Apr 20, 2005 | 09:28 PM
Dark-Knight's Avatar
Dark-Knight
Performance mods in my sig are very unobtrusive. Only visual clue is the ti exhaust tips, induction grills are almost never noticed.
Old Apr 20, 2005 | 09:34 PM
shurite44's Avatar
shurite44
Money no object I have to agree, 427.
Old Apr 20, 2005 | 09:38 PM
Tino's Avatar
Tino
I'm with Kyle, 427's make s__t happen ...
Tino
Old Apr 20, 2005 | 09:51 PM
uknowme2good's Avatar
uknowme2good
moneys no object.....super charger
Old Apr 20, 2005 | 10:06 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
if I could, I'd get mine Sullyfied...
Old Apr 20, 2005 | 10:11 PM
Try a Procharger and some headers. Should give you a big improvement in power. Then some Z06 sway bars and shocks, along with some non-runflat tires in the Z06 size should make the car handle like a dream.
Old Apr 20, 2005 | 10:21 PM
Sully C5's Avatar
Sully C5
Old Apr 20, 2005 | 10:25 PM
Sully C5's Avatar
Sully C5
Sully,
I really haven't noticed any negatives. I have a large BeCool radiator, so temperature is not an issue, even when running at the track.
I will be at Norris Motorsports tomorrow & will ask Mike what he thinks.
Old Apr 20, 2005 | 10:26 PM
c52k1NY's Avatar
c52k1NY
E.G. if you go with the underdrive I would get a electric water pump if possible.
Old Apr 20, 2005 | 10:34 PM
0EG@EnglandGreen
Supporting Tuner
That's what I thought. Thanks for the reply - and thanks as well, Sully. I am curious what Mike N has to say as well.
EG
Old Apr 20, 2005 | 10:51 PM
D C's Avatar
D C
USMC (retired)
To Unseen Mods???
