Height question ?Please help
Old Apr 20, 2005 | 09:13 PM
drumvette's Avatar
drumvette
Default Height question ?Please help
I have a navy 01 coupe that was lowered in the front before i bought it but, it's been driving me insane because it was way too low for me.I know people may disagree but, anyway...
I just had somebody raise it back up as far as they could and from the top (12 oclock) of my front tire to my inside highest point of my hub I haveabout 3 to 3 1/4 clearance.Is this the stock height?it still seems a little low and I'm supposedly maxed out.They also told me that the bolts were not cut or modded.
Can someone give me some input??
Thank you
Old Apr 20, 2005 | 10:32 PM
corvette dave's Avatar
corvette dave
Drum,
That sounds higher than stock.
You are using a fender for measurement, which is not accurate. If you ask 10 vette owners you will probably get 9 different stock heights.
Measure from the ground to the fender and post that. Somebody will be able to help you then.
It really boils down to just setting the height where you want it.
Dave
Old Apr 21, 2005 | 07:09 AM
FiberglassFan's Avatar
FiberglassFan
Originally Posted by corvette dave
Drum,
Dave
I agree with Dave. Sounds a but over height, but look tosee if you have stock tire size [ which set distance from ground to hub center ] and then measure from ground to the highest point on the arch opening. Most accurate method is to measure to the floor pan, which removes variations in fenders, but the fender will work in almost all non-racing situations, and is the measuring point in common use on the forum.
Old Apr 21, 2005 | 11:54 AM
FKING1's Avatar
FKING1
Before lowering my 00 Coupe , from wheel arch to ground:
frt=27-1/2, rr=28-7/8.
Fred
Old Apr 21, 2005 | 05:02 PM
drumvette's Avatar
drumvette
Default thanks i'll get back to ya
thanks for the replies .i'll measure and get back to you all
To Height question ?Please help
