If so you can do this job, get underneath the pump remove the drain and fill plug, let it drain, tighten the bottom plug. Using a pum, pump the fluid and Gm addittive to the diff. Fill till it comes out the hole, quickly put bolt in and tighten.
Did mine last week, pretty straight forward. Put the Redline 75W90 back in. (already has additive) Took about 1.8 quarts. Make sure car is level. The jack and stands tend to get in the way somewhat.
he said the 3.90's were new and he thinks the fluid needs changing
I understood that they are new. But when you buy a new car does anyone change out the rear end oil so soon.......No. I understand if someone wants to do it, to do it. But it's not required after the break mileage.
