driving up on 2x5s
Old Apr 22, 2005 | 12:11 AM
FallenWhun's Avatar
FallenWhun
Default driving up on 2x5s
I had four 1x5 boards laying around and with feeling the urge to lift my car Screwed them together thus = two 2x5s to drive up on... They're both 3 feet long and I was wondering if these board sizes were safe enough to drive up on to allow me to get the jack under my car, or is there a specific size of boards i should get?
Old Apr 22, 2005 | 12:23 AM
flash134's Avatar
flash134
St. Jude Donor '05
I used 9" wide X 1 3/4" thick X 18" long planks with no issues. I refered to this thread for ideas. I do have pucks but did not use them. Good Luck
http://www.z06vette.com/diy_lift.php
Old Apr 22, 2005 | 12:30 AM
Swany00's Avatar
Swany00
Veteran: Marine Corps
those should work fine
Old Apr 22, 2005 | 12:45 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
That's a bit light for me. I'd want a bit more wood there.
Old Apr 22, 2005 | 07:47 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Wouldn't we all.....
Old Apr 22, 2005 | 08:05 AM
NCSU SEE 5's Avatar
NCSU SEE 5
From: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
??????????????????? Oh, oh I get it!!!!!
Old Apr 22, 2005 | 09:12 AM
SilverRoadster00's Avatar
SilverRoadster00
I use 2X12's so I have a good base
Old Apr 22, 2005 | 09:19 AM
BWP 5P's Avatar
BWP 5P
St. Jude Contributor
Old Apr 22, 2005 | 12:56 PM
I'd probably want to use a little thicker pieces of wood, but that should work, especially if you are going to just use them to get the jack under the car.
Old Apr 22, 2005 | 01:23 PM
RCK1999's Avatar
RCK1999
however, you will get to the point where additional wood is not necessary and will actually interfere with what you are trying to do. Yes, you have to be careful as you get it up, but once it is up, then there is only so much wood that is needed. Once you have completed the task at hand, be careful removing the wood. Before removing wood, check for drips and leaks. Nothing worse than finding a drip once wood is removed. If you find something that is out of place, it will take some time to replace wood and raise everything again properly and safely. Above all else, please be safe and use extra precautions as you place your wood. An extra jack will add safety!
Old Apr 22, 2005 | 01:27 PM
98NassauBluC5's Avatar
98NassauBluC5
From: I'm a Texan, but I traded the horse for the Vette.
Yeah, it worked fine for me
To driving up on 2x5s
