[Z06] low oil level
Old Apr 22, 2005 | 10:49 AM
tmickey's Avatar
tmickey
Default low oil level
I was at the track last night and the low oil level started comming on.
Has anyone had the this problem? My 02, Z is still under warranty.
Old Apr 22, 2005 | 11:22 AM
Marine's Avatar
Marine
I have an 03 and my Low oil comes on for 2 reasons.
After a long drive I shut her down and start it up again after a short period of time.
Or when I get to HALF a quart low. I seem to lose half a quart ever 6000 miles.
Old Apr 22, 2005 | 12:28 PM
shaneotool's Avatar
shaneotool
It just means you need to add oil. No big deal. The light comes on when you are a quart low.
Old Apr 22, 2005 | 02:42 PM
F1_SS's Avatar
F1_SS
Check the oil. if you are indeed low then just add oil.
Old Apr 22, 2005 | 03:25 PM
User 81424's Avatar
User 81424
What kind of track were you at?
Old Apr 22, 2005 | 04:27 PM
hocheehoba's Avatar
hocheehoba
LS1 and LS6 are notorious for using oil. I have a Qt with me at all times.
Old Apr 22, 2005 | 06:14 PM
08msmZ06's Avatar
08msmZ06
Same here...
Old Apr 22, 2005 | 09:25 PM
Shylor's Avatar
Shylor
Need more information. What kind of track? What was your oil level before using the track? What was it after using the track? Is the warning light still on?
The C5 does not come with a dry sump oil system, so it is possible you yanked and banked the car to the point of activating the low oil warning. Or you just really worked the engine to the point where it used more oil than usual and now just needs topping off.
Old Apr 23, 2005 | 09:34 PM
tmickey's Avatar
tmickey
I was at the drag strip. I checked the oil level after a run when the low oil level warning came on. The oil level was low by 1-1 1/2 quarts low.
After the car sit for a few minuntes, it would be back at a normal level.
Old Apr 23, 2005 | 10:47 PM
Shylor's Avatar
Shylor
Are you using 5W-30 Mobil 1 and was it filled to the top of the oil dip stick mark before the run?
You can't get a true oil level reading by checking it so soon after a run. You have to shut it down and let it sit for a few minutes, so the oil has a chance to drain first. And I think it is supposed to be checked cold for a true reading.
I'm pretty sure some people add an extra half to a quart of oil for racing. All those high revs can leave little left in the oil pan and may be the reason for the low oil warning light.
If I'm way off here someone else chime in.
Old Apr 24, 2005 | 06:49 PM
Chuck Harmon's Avatar
Chuck Harmon
The video that came thw my ZO6 said to overfill the sump with an extra quart for road racing.
Chuck
Chuck Harmon
The video that came with my ZO6 said to overfill the sump with an extra quart for road racing.
Chuck
Old Apr 25, 2005 | 10:49 AM
tmickey's Avatar
tmickey
The oil was at the bottom of the dip stick. After making a run.
Old Apr 25, 2005 | 06:12 PM
Shylor's Avatar
Shylor
Again, checking the oil to soon after shut down does not give you an accurate reading. Was the oil within limits prior to your run?
Old Apr 25, 2005 | 11:30 PM
tmickey's Avatar
tmickey
Yes the oil was at normal level before the run. The oil was about halfway on the hatch marks on the dip stick. After a run the oil would be at the very end of the dip stick. I went to my local dealer. The service manager said I needed to add oil. He also said their is a service bulletin on that problem. I feel this is a major problem. I expect GM to know what the fix is for this problem. Yes the video says to add a quart of oil when racing the car. My owner manual says a quart when racing, but remove it under normal driving. If an extra quart is needed racing, how in the HHHH could it hurt driving normally?
Old Apr 26, 2005 | 10:21 AM
robvuk's Avatar
robvuk
The extra quart is required for roadracing. The hard g-forces combined with high revs will keep the oil from draining back into the pan properly and could cause a sudden drop in pressure. If you were drag racing, your oil level should be back to normal within a minute or two of shutting it off after returning to the pits. If it takes longer than that, there is a problem with the drain holes being blocked. This would not be a good thing in either case.
Old Apr 26, 2005 | 12:55 PM
LuS1fer's Avatar
LuS1fer
A friend has an 03. He was racing a TVR Griffith when the low oil level light came on. He checked it and it was fine so he thinks the sender might be dodgy. He let the TVR go as he didn't want to damnage the engine but the TVR owner knows he'd get his butt kicked and anyway the TVR ECU is fried.
To low oil level
Old Apr 26, 2005 | 01:18 PM
3 Z06ZR1's Avatar
3 Z06ZR1
mines full when I change it, I use Syntec, Drained the mobil 1
first week I got it.
Had 3-f body's. they didn't like Mobil 1 either.
Old Apr 26, 2005 | 01:32 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Old Apr 26, 2005 | 03:28 PM
XotiK ZO6's Avatar
XotiK ZO6
Chuck
Words of wisdom. The video that came with mine said the same thing... and they say guys don't know how to read (watch in this case) instructions!
