Need install help
Old Apr 22, 2005 | 07:42 PM
jpc0011's Avatar
jpc0011
Default Need install help
Can anyone direct me to a post? I have purchased GM ceramic pads, Zo6 Calipers and new slotted cross drilled rotors. What should it cost to have installed vs diy...
Old Apr 22, 2005 | 08:26 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
Old Apr 22, 2005 | 08:35 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Have you done brakes before? If so that question is kind of a no brainer. Yes it is a Corvette, no it will not bite. If you need help just pm me and I'll walk you through it. FYI, GM dealers charge $75.00 and up per hour, at least the one's that know what they are doing. Also, if you didn't buy the parts from them, they'll probably make it up somehow.
Old Apr 23, 2005 | 07:01 AM
Wildcat99's Avatar
Wildcat99
Its not very hard after you get the bolts that holds the rotors on broke loose. If you decide to do it, you can get all the help you need right here. I put mine on 6 months ago, I had a quote of 175$ for the labor only. Let us know what you decide.
Old Apr 23, 2005 | 08:52 AM
jpc0011's Avatar
jpc0011
I called dealer today. They quoted a price of 490.00 + tax for "labor only". what would install time be per wheel (actual). Thanks
Old Apr 23, 2005 | 09:17 AM
MikeTennent's Avatar
MikeTennent
Default Do it yourself...
It isn't rocket science. If you have the tools or can get your hands on them, do it yourself. You do need a torque wrench.
Old Apr 23, 2005 | 12:37 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
and a big honking clamp..
Old Apr 23, 2005 | 12:39 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Where are you located? I'll do 'em for nothin' if you're close.
Old Apr 23, 2005 | 12:45 PM
TEXASCOUPE's Avatar
TEXASCOUPE
I agree the front pads are pretty simple. But I'm not sure how to tackle the rears because of the seperate emergency brake pads. How difficult is that to do?
Old Apr 23, 2005 | 11:19 PM
MyVetteDream
Parking Brake Adjustment -- 1 of 1
Date Published: 2002-05-01
Submitter's Name: Bill Matera
Email Address: wmatera@snip.net
Corvetteforum.com Member Alias: Evil-Twin
I posted this fix several years ago, but it was lost in the software upgrade... When My C5 was new the e brake barely worked,, I took it to the dealer, and was told that brakes are a wear item and that I would have to pay for new shoes.. the car had less than 1000 miles on it .. the e brake only engages when the car is stopped so how could they be worn.. Any way I decided to take a look ans see if i could do anything..I was not crazy about the dealer touching my car anyway.. OK.. here we go.. the e brake works similar to the e brake on most cars with rear drum brakes.. with that in mind... jack up the rear of the car...remove the wheels...then remove the bolts for the calipers...then the calipers and pads...you will see the caliper bracket.. it has two bolts that hold this to the brake backing plate.. they are very very tight... but they will come off ( They are 125 ft pounds with loctite)... Once the bracket is off you can remove the rotor ( make sure the e brake is not engaged ).....Next.. you will see how the system works.. it has a set of shoe brakes .. and the rotor has an internal drum... In the last few years I have found that many many C5 come from the factory with poorly adjusted e brakes... Now locate the star adjuster.... turn it out to make the shoes grow in diameter...( Mine were out 33 clicks)... I did ten clicks at a time and the slid the rotor back on.. I did three sets of ten before I could feel any drag... I then clicked five more and could not get the rotor on...I then backed off two clicks and got the rotor on.. it was tight when I started it on the shoes but when i finally seated it it was perfect.. I then did the other side.. it was out exactly the same amount.... I then put everything back...Now for the test...When I engaged the e brake.. it locked up the brakes at a point about 45 degrees.... 90 degrees being straight up.. the lock up was so positive...I knew I did it right..next .. to check the release .. I took the car to a hill... set the e brake .. car in neutral and it stayed there ... then to check on the release.. I slowly disengaged the ebrake...and found that the shoes where totally retracted after only an inch of lever release...after this fix I could stop the car using only the ebrake with the car doing ten miles an hour...The ebrake also has an auto adjust feature.. but it will only work if your e brake lever is between 45 degrees and 55 degrees..if your ebrake is out further than that the e beake will not auto adjust..... ( AUTOADJUST feature ) roll the car backwards on a hill.. or in reverse @ 5 mph..pull up on the e brake lever... this will slam your car to an abrupt stop.. the engagement of the shoes to the drum while the car is moving backwards will cause the shoe assembly to flex.. it is the flex that causes the blade to click the adjusting star one click... Do this three or four times and it will expand your shoes.. you can not over tighten thes shoes... if it needs two clicks to get to max... and you do four clicks.. it will only adjust the star two clicks.. Also remember to use loctite on the brackets and caliper bolts..If you have any questions on this repair .. feel free to e mail me or instant message me.. Good Luck.. Many people have emailed me with their positive results from this fix... Bill ( Evil-Twin )
Old Apr 24, 2005 | 05:44 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Thanks for the detailed instructions,will give it a try.
Old May 1, 2005 | 10:39 AM
Mickelina's Avatar
Mickelina
And this bolt to calipers need a torque of what?
To Need install help
