Jack stands ????
Old Apr 26, 2005 | 02:55 PM
vette dan's Avatar
vette dan
Vette Dan
Default Jack stands ????
How does one jack up vette to put it on jack stands ???? Where do you put jack stands if you use jacking points to raise car ????
Old Apr 26, 2005 | 03:05 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Underneath the crossmembers with a board in between.
Old Apr 26, 2005 | 03:20 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
I also use the method of placing the jackstands under the crossmembers. This way, there is no need for jacking pucks.
http://www.z06vette.com/diy_lift.php
Old Apr 26, 2005 | 05:44 PM
I place jack stands under the crossmembers. I use a floor jack to get the car up high enough to slide the stand to the right location.
Old Apr 26, 2005 | 06:55 PM
Shylor's Avatar
Shylor
Owners manual, service manual or video explain it all.
Old Apr 26, 2005 | 06:59 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Go here! http://97vette.com/howto/carlift/index.html
Old Apr 26, 2005 | 07:01 PM
charliesc5's Avatar
charliesc5
great write-up
Old Apr 26, 2005 | 07:12 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Here's mine during my Stinger install....
More pics here.....
Old Apr 26, 2005 | 08:02 PM
iceburgh's Avatar
iceburgh
St. Jude Donor '03-'04-'05-'06-'07-'10
Front
Rear
Old Apr 26, 2005 | 08:08 PM
Special K's Avatar
Special K
Right, as long as you don't take it to a dealer. Then be prepared. Some of them don't use pucks either.
Bob
Old Apr 26, 2005 | 08:24 PM
JChrisF's Avatar
JChrisF
From the tech section:
Old Apr 26, 2005 | 11:09 PM
PetalBombC5's Avatar
PetalBombC5
To Jack stands ????
