Dimensions needed
Old Apr 28, 2005 | 08:14 PM
bluewire's Avatar
bluewire
Active Streak: 90 Days
Default Dimensions needed
I was wondering if someone could give me the dimensions of thier jacking pucks? I need to make a set for my car.
Thanks,
Old Apr 28, 2005 | 08:25 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
mine are made from hockey pucks - perfect size. I used eye bolts (1" diameter eye) with most of the threads cut off so they didn't stick out the bottom of the hockey puck. Drill a hole right in th center of the puck, screw in the eye bolt so it is almost all the way in. If you've got it right you should be able to put them into the shipping slot, twist them clockwise and they should hold in place. Screw the eye bolt in or out to adjust until they stay in there for you.
Old Apr 28, 2005 | 08:27 PM
usd2sing's Avatar
usd2sing
go to your local sporting goods store (oshmans, sport authority, etc.. pick up a couple of hockey pucks.
got mine for $.99 each. then bought a couple of 1 1/2in eye screws/bolts at home depot for $.29 each... screwed them into the center of the hockey pucks...less than $6 invested for a set of 4 and use them often..
Old Apr 28, 2005 | 08:42 PM
Patches's Avatar
Patches
If you're going to make them yourself - http://97vette.com/howto/liftpads/index.html
Otherwise, buy from Elite Engineering for a great price in you choice of color. jmho
Old Apr 28, 2005 | 08:48 PM
bluewire's Avatar
bluewire
Those are the ones I want the dimensions for, Then I can machine a pair myself. Thanks for the hockey puck idea, if I can't det the dims. i'll just use that.
Old Apr 28, 2005 | 08:53 PM
Railfan's Avatar
Railfan
I just used mine from Elite Engineering when I had my new wheels put on and they worked great.
Sorry, just thought I'd throw that in. :o
To Dimensions needed
