[Z06] Faulty window switch???
Old Apr 29, 2005 | 07:44 PM
Popclutch's Avatar
Popclutch
Default Faulty window switch???
[B]Left work today and as usual went to put the windows down on my 02 Z and the passenger side appears to have taken a dump. I can hear click click but NO movement. Suggestions?? Thanks, Pop.
Old Apr 30, 2005 | 08:04 AM
fasterz06's Avatar
fasterz06
I have a 2002 Z06 too and have same problem with the passenger window.....so let's wait if someone gives us a suggestion.
Old Apr 30, 2005 | 09:02 AM
Popclutch's Avatar
Popclutch
ANYBODY encountered this before other than myself and fasterZO6?
Pop.
Old Apr 30, 2005 | 09:04 AM
barondw's Avatar
barondw
http://www.crossedflags.com/nuke/htm...wtopic&t=14666
Old Apr 30, 2005 | 01:15 PM
rhinoevans's Avatar
rhinoevans
I have an 03 and just had the left motor replaced for the passenger window. First it failed to go down. Then worked the next day, went down but not up. Fixed under warrenty for $400
Old May 4, 2005 | 03:30 PM
Popclutch's Avatar
Popclutch
Thanks for the insight!! LOL!! The great American fix!! Get a bigger hammer and beat on it. I'll try this one!.. Pop.
Old May 4, 2005 | 11:32 PM
trs-ZO6's Avatar
trs-ZO6
Cruising
My entire control module located in the driver's door on my '02 Z was recently replaced under warranty.
Old May 5, 2005 | 06:31 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
The easiest fix to try is: Hold the window switch in the down position while you close the door hard. Sometimes this works to free the window regulator and get things working again. The regulators have a tendency to get hung up and the slamming of the door with the switch held down can get it going again.
If that doesn't work you are probably looking at replacing the window regulator. They typically only last a couple of years in these car and then crap out.
Old May 8, 2005 | 04:02 PM
Popclutch's Avatar
Popclutch
UNBELIEVABLE!!!! I tried the switch/slam the door thing and sure as crap IT WORKED!!! I figure it took a UFgrad to figure this one out!! LOL!! I went to FSU!!!
Thanks for the help!...Pop.
Old May 8, 2005 | 05:39 PM
Z06ufgrad2002
Now you deserve a beer.
To Faulty window switch???
