[Z06] Track preparation
Old May 1, 2005 | 05:04 PM
trs-ZO6's Avatar
trs-ZO6
Cruising
Default Track preparation
Going to the track(road course) for my initial outing this week.I was planning to add extra 1/2 qt of oil and bring tire pressures up to 38 lbs(Toyo - T1-S).Comments please and/or any other suggestions to enhance the performance without damaging the car.
Old May 1, 2005 | 05:20 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
1. Add 1 quart of oil
2. Make sure bake pads are over 1/2 life
3. Bleed brakes and change stock fluid out for high-temp
4. Start with tires around 36-36 psi cold. They should be 38-40 hot for street tires.
5. Wrap tie-rod ends in high temp shielding (they'll melt internally)
6. I'd pick up a spare set of front rotors from NAPA just for insurance.
Cya,
B
Old May 1, 2005 | 06:29 PM
AU N EGL's Avatar
AU N EGL
Extra FULL quart of oil.
tires should be 40* or soo HOT, when you come off the track to 36* cold.
Dot 4 brake fluid. High temp
Leave the Ego at home and have fun.
Old May 1, 2005 | 07:23 PM
trs-ZO6's Avatar
trs-ZO6
Cruising
Thanks for input - not planning to run hard or long for initial outing just want to experience car in stock form as planning some mods shortly.Kind regards
Old May 1, 2005 | 10:38 PM
FST NUF's Avatar
FST NUF
Never heard of the tie rod end internals melting. Is this from experience or is this a fact gleened from a reliable source?
Old May 1, 2005 | 11:14 PM
levettegrl's Avatar
levettegrl
Cruise-In IV Veteran
here's more to add:
long sleeves/pants, natural materials (jeans and cotton shirt are perfect)
lots of water, you will be dehydrated
bring a torque wrench if you have it and tire guage, check your lug nuts and tire pressure regularly
empty out your car completely, bring trash bag to store things in (in case it rains!)
cash for lunch at the track
helmet (SA2000 or better, full face is best)
listen to your instructor and try to get a ride in one of their cars
Old May 2, 2005 | 10:32 PM
Cobra4B's Avatar
Cobra4B
Common knowledge in the auto-x/road racing forum. Over time they'll get soft. Also the outer rubber covers will melt. Mine had excessive play in them so I replaced them with VB&P HD ones. They're all metal, no plastic internals. I still cover the rubber boots in head tape.
Old May 2, 2005 | 10:46 PM
User 81424's Avatar
User 81424
Our stock tie rod ends have plastic cups in them, after market and ones that come on track ready cars like a GT-3 have brass cups in them.
Old May 3, 2005 | 12:19 AM
RyanZ06's Avatar
RyanZ06
Can you link me to these parts?
Old May 3, 2005 | 08:13 AM
ErnieN85's Avatar
ErnieN85
fronts http://www.vbandp.com/detail.aspx?ID=771
rears http://www.vbandp.com/detail.aspx?ID=772
Old May 3, 2005 | 10:02 AM
robvuk's Avatar
robvuk
If this is your first outing, I wouldn't worry about melting any tie rod ends. I don't understand putting tape over them either. Seems to me that would retain more heat. The only heat you have to worry about comes from braking. I drive/brake pretty hard and I have melted the rubber boots off the caliper pistons. I doubt you'll be doing anything like that on your first several times out. Just make sure you have the DOT 4 brake fluid and good pads. Have fun.
To Track preparation
