Is This Normal?
Old May 1, 2005 | 07:08 PM
Southview's Avatar
Southview
Default Is This Normal?
When I go to turn the key to start the car,it acts like it is on a delay.Meaning,I turn it to start and after a 2 second delay then it turns over.The battery is good.It seems to be getting worse the more the day went on.My buddy's car starts as soon as you turn the keyHas anybody experienced this before.I am going to East Coast Supercharging on thursday and don't want to be stranded on that 10 round trip.The car is an 01 A4 vert.HELP!!!!
Old May 1, 2005 | 07:11 PM
vette2k1's Avatar
vette2k1
Mine is a 01 A4 coupe and it doesn't have that problem. It sounds like the battery or the starter may be weakening.
Old May 1, 2005 | 08:33 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Certainly not normal. Might want to consider an electrical check on the system.
Old May 1, 2005 | 08:58 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
clean the chip on the key..
Old May 1, 2005 | 09:06 PM
I'd say that is not normal. Mine certainly doesn't hesitate to start like that.
Old May 1, 2005 | 10:15 PM
jrose7004's Avatar
jrose7004
Me either!
Old May 1, 2005 | 10:21 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Old May 1, 2005 | 10:22 PM
MDriveMode's Avatar
MDriveMode
Good point Grumpy! Try using a pensil eraser or electrical cleaner on the metal part enclosed in black plastic. The resistance in the key may be causing the hesitation.
Old May 1, 2005 | 11:56 PM
vet85's Avatar
vet85
whan i got my 02vert it did the same thing .someone told me to clean my key by rubbing it on my blue jeans.keep in mind i was out of town and strainded.so i did it, and that was 10 months ago and it hasnt happened again ...cant hurt 2 try .
Old May 2, 2005 | 03:37 PM
Southview's Avatar
Southview
I sure hope that is it.I will try when I get home.THANKS
Old May 2, 2005 | 03:49 PM
JeepTJ's Avatar
JeepTJ
Normal is a button on your dishwasher. This is not normal.
Old May 8, 2005 | 08:40 AM
mrgilson's Avatar
mrgilson
1st Gear
Why go to ECS? There are so many other places that will fix your car the first time and stand behind their work. I'll never go to ECS again.
Old May 8, 2005 | 11:32 AM
JH's Avatar
JH
Excellent advice. At any rate, the delay is not normal.
Old May 8, 2005 | 04:38 PM
wannabe-psi's Avatar
wannabe-psi
----snake bitten----
ttt
Old May 8, 2005 | 09:56 PM
Southview's Avatar
Southview
Found the problem.I installed my alky kit and tied the power into the keyed power wire in the oassenger kick panel.The same wire my radio power wire is tied into.Well for some reason the fuse blew which led me to investigate.I disconnected the alky power from that line and replaced the fuse.NO MORE DELAY!I tapped the alky power into the big orange ignition wire under the column and no more problem.Still don't know why it could't handle them both.
Old May 8, 2005 | 11:49 PM
wannabe-psi
what fuse!!!
thx frank
Old May 8, 2005 | 11:51 PM
DeeGee's Avatar
DeeGee
To Is This Normal?
Old May 9, 2005 | 12:59 AM
I'd say not normal. Mine kicks right over.
Old May 9, 2005 | 11:57 AM
Southview's Avatar
Southview
It was a 20 amp towards the top of the box.I don't have the car so I don't remember the #.The wires that I tied into were the 3 extra ones by the fuse panel.I think I tied it to the yellow wire.
Old May 9, 2005 | 11:01 PM
wannabe-psi
thx!!!
frank
