active handling competition mode
Old May 3, 2005 | 02:36 AM
flyzlow's Avatar
flyzlow
Default active handling competition mode
I HAVE READ THAT HOLDING THE ACTIVE HANDLING BUTTON DOWN FOR A FEW SECONDS ACTIVATES COMPETITION MODE. WILL SOMEONE EXPLAIN EXACTLY WHAT TAKES PLACE AND WHAT IT DOES? I PUT MINE IN COMP. MODE LAST NIGHT just to see if it lit up on the dash. It did, now what? (Oops, had caps lock on) Thanks for input on this.
Old May 3, 2005 | 03:14 AM
GrayC5's Avatar
GrayC5
You can find more info on the two generations of Active Handling and the Competitive Driving Mode at the following links. The first link is about 1st Generation Handling and other link about 2nd Generation Active Handling:
Active Handling System
Model Year 2001 Press Release - More Agility...
Old May 3, 2005 | 03:21 AM
flyzlow's Avatar
flyzlow
Thankyou GreyC5. That helps and will be more fun too.
Old May 3, 2005 | 03:41 AM
GrayC5's Avatar
GrayC5
You're most welcome. Do be careful though when you turn both AH/TC off or just the TC off (Competitive Mode). Several here have learned the hard way that these cars can get away from you very quickly.
Old May 3, 2005 | 11:54 AM
flyzlow's Avatar
flyzlow
Thanks again Gray C5. i will try to keep her on the straight and narrow and shiny side up.
To active handling competition mode
