Battery problem update
Old May 3, 2005 | 01:39 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Default Battery problem update
Just got back from Interstate Batteries since Costco was out of stock of the Red Tops. Was running a special on the SC75U for 104.95. Put it in and so far all appears to be ok. Talked to the dealer about the problem and was told if the battery didn't solve the problem the alt. would be covered under the extended warranty. So, I'll keep my fingers crossed everything's cool.
Old May 3, 2005 | 05:41 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
glad to hear that... hope the battery takes care of it........
Old May 3, 2005 | 05:42 PM
Hope it is only the battery. If not, at least your warranty will help.
Old May 3, 2005 | 07:12 PM
jpc0011's Avatar
jpc0011
I hope the battery works out. Its nice to know that the dealer is stepping up if problem should continue.
Old May 3, 2005 | 07:18 PM
TEXASCOUPE's Avatar
TEXASCOUPE
I agree. So far this dealer has treated us fair all the times we've been there. Sort of unusual but I guess there are some dealers you can trust.
Old May 4, 2005 | 07:18 AM
kg54trains's Avatar
kg54trains
Do not waite to see if it is the alternator because there is test equipment that can measure the charging system and that includes the alternator. This would give you the answer now and not later when your battery is dead.
Old May 4, 2005 | 08:49 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Battery
________________________________________ ____________________
[mrm1149]glad to hear that... hope the battery takes care of it........
When it comes time to change my battery......I'm going with the Interstate Battery. Not pleased with some of the stories about the "red" and "yellow" top batteries.
To Battery problem update
