What should gauges read?
Old May 3, 2005 | 05:45 PM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
Default What should gauges read?
In the corvette - 2000 c5 6spd with corsa exhaust xpipe and blackwing.. what should all the gauges read? should they all be half way or? The car I am buying from someone with 33k miles.. What should the guages read? I know the bottom right is fuel gauge and obviously that read ur gas .. thanks
But top left is something that says psi?
Bottom left is temperature
Top right is battery volts?
Old May 3, 2005 | 05:48 PM
srsjuju's Avatar
srsjuju
im not sure if this is what you want but
the top left is oil, bottom is temp upper right is volts lower is fuel
big one in the middle left is tach right is speed
Old May 3, 2005 | 05:49 PM
Z0Sick6's Avatar
Z0Sick6
St. Jude Donor '05
yes thats them.. should they all be in the middle? I sawpeople posting that 1 of their gauges over time falters or something.. that it goes all the way to 80? I think it is that i read
To What should gauges read?
