Driveway problems, seeking advice
Old May 4, 2005 | 01:35 AM
Venos's Avatar
Venos
Default Driveway problems, seeking advice
My '98 is lowered 1.5", and scrapping the front air dam is a common occurance for me, but now I'm looking into buying a house that has a driveway that I currently cannot drive up.
The driveway setup is like this, starting from the street: street/drop 2ish inches for rain drainage/first incline slope/sidewalk/final incline slope.
I've been told I will probably be able to fill in a portion of the rain drainage area so that I can move my front end up to the sidewalk much easier, but I probably won't be able to modify the sidewalk in any way. The problem would be getting the whole car up on the final incline so that I can pull up into the carport.
Should raising my car back up to the original height possibly allow for clearance? Should I add those frame roller things?
Here's a link to the property listing with a partial pic of the driveway so you can get an idea of the slope angle.
House/Driveway
Old May 4, 2005 | 01:39 AM
Chris.Shea's Avatar
Chris.Shea
ever try going up backwards with some one to watch for clearance?
Old May 4, 2005 | 01:44 AM
Venos's Avatar
Venos
Not yet. Every place that I've done that so far, the air dam still scrapes (like my current driveway), but I'm sure it may help a bit.
Old May 4, 2005 | 01:47 AM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Reminds me of when my wife and I were looking for a house. We found the "perfect" house. We loved the layout and everything else about it except the driveway. It was too steep for anything other than a Hummer (seemed like).
We kept looking.
Good luck.
Old May 4, 2005 | 01:48 AM
markcz's Avatar
markcz
Is it possible to hit the driveway at a 45* angle? My front end would scrape real bad if I went straight into my drive, but it just happens that my street is a dead end so I am always turning right to go up my driveway. A 45* approach angle is more than enough to get the needed clearance.
Old May 4, 2005 | 02:27 AM
Rage@AutoBuffs's Avatar
0Rage@AutoBuffs
Former Vendor
St. Jude Donor '10
Just put on chin spoiler, for sure scraper! Went to Home Depot, bought (2) 2x12x12, cut in 1/2, ramp it up the driveway, it sucks, but no more scraping.
Old May 4, 2005 | 03:41 AM
c52k1NY's Avatar
c52k1NY
I just had my whole driveway regraded so my vette would not scrape
Old May 4, 2005 | 03:57 AM
Venos's Avatar
Venos
I tried that on the first attempt, but it didn't help much. I will probably make a temporary ramp for the first incline this weekend to see if I can make it up on the sidewalk without scrapping too hard.
Old May 4, 2005 | 07:26 AM
1Patriot's Avatar
1Patriot
First rule of house shopping; no slopes in either direction, no ups, no downs. Learned that a long time ago and still practice it.
No downs will keep you out of most flood plaines and creek beds and no ups means when it snows or freezes, you can stil get in and out of the garage.
If builders insist on using any such lots, let them eat cake.
Old May 4, 2005 | 08:54 AM
Venos's Avatar
Venos
It doesn't snow here
This house is on the top point of the hill that the block is sitting on, so that won't be a problem either. But this is Alabama, and houses with sloped driveways heavily outnumber those with flat driveways. It's VERY difficult to find a reasonable house in Montgomery with a flat driveway.
Old May 4, 2005 | 09:04 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
I have a similar issue.
Pulling in at a sharp angle gets it to where just one corner of the plastic air dam hits (it flexes - no problem). I also have to back down the drive to avoid hitting the underside of the bumper.
I understand all about driveways in AL, some can be very steep with no chance of getting a vette in or out.
Good luck.
Old May 4, 2005 | 09:05 AM
NickP's Avatar
NickP
Looks like the driveway can be fixed with minor adjustment that no one will be able to discern. It looks like you got a lot of house for your money. At least that's how it looks from where I'm living.
Old May 4, 2005 | 09:27 AM
vette 85's Avatar
vette 85
I have the same problem. I was thinking about putting a 1/4" mat on the concrete section where it tranitions to the street.
Old May 4, 2005 | 09:30 AM
ArmyVette's Avatar
ArmyVette
The heck with the driveway. Did you see the price of the house? $115,000 doesn't buy you enough room to put up a tent around here.
I'm moving to Alabama!
Old May 4, 2005 | 11:08 AM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
That's what I was thinking
Old May 4, 2005 | 12:16 PM
ClovisFox's Avatar
ClovisFox
In your case I would not recommend the skid bar wheels. I have them and they only work well when you go straight into a small incline. I have a stupid rolled curb at my house which requires me to approach at an angle. Unfortunately, when the wheels engage they are hitting at an angle causing them to no longer point straight.
Looks like you need some kind of a James Bond device. Good luck.
Old May 4, 2005 | 12:30 PM
mrgil's Avatar
mrgil
Burnout
This is on the right track.. Only you need a full driveway width 2 X 4 laid in the gutter and approach at a 45 degree angle.... Works for me
mrgil
To Driveway problems, seeking advice
Old May 4, 2005 | 12:47 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
no doubt, that's a down payment out here!
Old May 4, 2005 | 01:34 PM
Venos's Avatar
Venos
115 is just asking price, but hopefully I'll get it for under 100 It's also in one of the best neighborhoods in town. It's a fixer-uper house for sure, but it's mostly cosmetic work, etc. The real problem is that the pool in the backyard is TRASHED.
I drove by and checked it again this morning, and I THINK I should be able to get up the driveway as long as I decrease the angle of the incline coming off the street. I will probably have to raise it back up to stock height though
I now have a new hatred for sidewalks.
Old May 4, 2005 | 01:40 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I have a similar problem. I attack it at a 45 degree angle from the left turning in and when I back out I'm at a 45 degree angle to the right. Both sides get even wear.
