Vert Owners???
Or has anyone added a fisheye?
Or do you just go for it?
be careful I would take one for a ride first.
But then again I love the vert and would not change it for any other
Here is the proceedure for adjusting them.
Center the rearview mirror such that when looking straight ahead shift your eyes to the rearview mirror without moving your head. The middle button on the mirror should be centered. You can raise the trunk lid a little to insure the trunk emblem in centered in the mirror.
For the next steps you will need a multi lane highway. To adjust the left outside mirror, let a car slowly overtake you in the left lane. Again looking ahead just moving your eyes keeping your head still, the car will start to go out of the left corner of the rearview mirror. When the front 1/2 of the car is out of the rearview mirror the front 1/2 of the car only should be in the right corner of the left outside mirror. Adjust the outside mirror out until this happens. The car will start to dissappear from the left outside mirror, when only the back 1/2 of the car is visible in the mirror, turn your head and look out the driver's side window, the car will be visible. Adjust the right outside mirror similar to the above.
If a car is overtaking you, you can see how the car moves from the rearview to the outside mirror, to being visible. Never out of sight, no blind spots.
If the rearview mirror is clear, the outside mirror is clear and there is no car visible out the side window, you are guaranteed there is no car in that lane.
Just take you time and look twice!
It kinda boils down to, with head straight, then turned towards mirror (either side) you should NOT see the side of your car in your side mirror. If you do, your mirror is adjusted to far in. Most people like to see the side of the car for visual clue/reference but its not necessary once you are confident of what you are viewing in your side mirrors.
Following the description above, your view into the mirror will end up being a couple of inches away from the side of your car.
Great post 50 4ever
..rickko..
