SS Insert Install ???
Old May 5, 2005 | 02:43 PM
golddog's Avatar
golddog
St. Jude Donor '05 thru '24
Default SS Insert Install ???
When applying the adhesive promoter, what is best to use? Q-tips etc.
Also, I assume you apply a thin layer. Any hints are greatly appreciated.
Old May 5, 2005 | 02:44 PM
adolph's Avatar
adolph
Just make sure the area is clean, use alcohol for proper cleaning.
Old May 5, 2005 | 02:52 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
I only used Q-tips to clean the area where the letters will go.
Then I applied the adhesive promoter straight from the sponge. I slit the package and pulled out the sponge a little and dabbed it on.
Old May 5, 2005 | 02:54 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
Wipe down the area with denatured alcohol before you do anything. Then try lining up the letters before taking off the backing. Watch out for the letter "E". If you do it wrong, it will look like CORVCTTC.
Good luck and post some pics when done!
Old May 5, 2005 | 03:18 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Might help to apply heat to the adhesive...use a hair-dryer or heat gun...helps the adhesive sitck better...
Old May 5, 2005 | 03:59 PM
JLA's Avatar
JLA
I just did mine and was a little spooked when I started. Had a beer, did a test run, cleaned the area, peeled the letters, stuck 'em in, had more beer. It really isn't hard to do.
Old May 5, 2005 | 04:01 PM
ExRedRacer's Avatar
ExRedRacer
Did you get 'em on straight?
Old May 5, 2005 | 07:21 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
gotta ask........what in the name of gm is adhesive promoter? fancy name for denatured alcohol??
Old May 5, 2005 | 07:36 PM
Target Chaser
St. Jude Donor '05
The adhesive promoter comes in little packets along with the letters and enhances the adhesiveness of the sticky tape behind the letters. You still need to clean with denatured alcohol before applying the promoter.
Old May 5, 2005 | 07:43 PM
JLA's Avatar
JLA
Yep.
Old May 5, 2005 | 08:39 PM
NickP's Avatar
NickP
So your saying beer helps? Any particular brand? Miller lite?
Old May 5, 2005 | 09:25 PM
deemer's Avatar
deemer
You may want to try this to insure all letters are correct, especially the "E". Before you remove the protective backing from each letter place a small piece of scotch tape to the top of the letter or piece (middle insert for the letter "E"). Then very lightly stick the scotch tape to the vette and align the letter, when you have it aligned, remove the protective covering and allow the letter to settle on the vett. Make one final check for alignment and if it's OK press the letter in place. When I did mine I was scared to death of fouling it up, but with the procedure outlined above, it came out perfect on the front and back. By the way, if you plan on doing the front license plate holder, you have to bend the the "V" slightly (atleast I had too on my 03). Good luck, you love the results.
Old May 5, 2005 | 10:15 PM
Z0SLIK's Avatar
Z0SLIK
Throw it away. If the surface is clean you don't need it.
To SS Insert Install ???
