fog lite replacement ?
Old May 5, 2005 | 08:45 PM
26sonic's Avatar
26sonic
Default fog lite replacement ?
could someone tell me how to remove the fog lite on my 2000 c5 (pass side ) and the bulb part # ? i could not find this info in the owners manual .
Old May 5, 2005 | 08:55 PM
Anthony01's Avatar
Anthony01
Fog Lamp Bulb Replacement - Front
Removal Procedure
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the front fascia lower close out panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Release the brake caliper cooling duct from the front fascia and position the duct aside.
Disconnect the front fog lamp electrical connector from the fog lamp bulb/socket.
Remove the fog lamp bulb/socket from the fog lamp. Rotate the fog lamp bulb/socket counterclockwise to release it from fog lamp.
Here is the complete list of all the bulbs of a C5 Hope this helps
CHEVROLET Corvette
Low beam headlamp
9006
9006ST Silverstar High Performance Lighting: the whitest and brightest Halogen
9006XV XtraVision Halogen Upgrade: Up to 20% Brighter
9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
High beam headlamp
9005
9005ST Silverstar High Performance Lighting: the whitest and brightest Halogen
9005CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
4157NALL
4157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
4157NALL
Rear turn signal
3057
3057LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
3057
Stop light
3057
High mount stop light
%COM
Fog/Driving light
893
893ST Silverstar High Performance Lighting: the whitest and brightest Halogen
899
License plate
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
2057
2057LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
Rear sidemarker
194
Glove box
194
Map light
212-2
Step/Courtesy light
194
37
Under hood light
561
Instrument-general
194
Automatic transmission indicator
194
Old May 5, 2005 | 08:59 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
IF you have a small arm you can raise the hood, turn the headlights on, then to "park" leaving the headlights up. Disconnect the battery if you wish. Remove the plastic bezel around the headlight assy. on the side of the discrepant fog light bulb. Reach in, unplug the wire harness and twist the bulb assy. out. One of mine was pretty tough and took a little help to get "unlocked".
Old May 5, 2005 | 09:48 PM
DreamVette97's Avatar
DreamVette97
Whatever you do, just dont listen to Anthony01. That is some BAD advice! Just do what the 3rd post says. Its simple. Go to Wal-Mart for the bulb.
Old May 5, 2005 | 10:41 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
3 minute job..
Old May 6, 2005 | 12:21 AM
George8211's Avatar
George8211
Geez... Kinda harsh, the guy takes time out of his day to type how to replace the bulb... and you slam him Have some class... if you think you have a better way state your way, leaving some respect on the table for others.
Old May 6, 2005 | 12:37 AM
005's Avatar
005
Old May 6, 2005 | 12:48 AM
KonaVette's Avatar
KonaVette
St. Jude Donor '03-'04-'05
Very nice of you Anthony01. I have saved that to file. Very useful information
To fog lite replacement ?
