Flat Tire?
Old May 7, 2005 | 05:23 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default Flat Tire?
Everyone,
I just got back from deployment and returned to find that one of my front RUN-FLATS was "FLAT", so I said, "Great time to buy new tires."
My RUN-FLATS were just passing 4 years of age and I went with the NON-RUN-FLATS KUMHO Ecsta MX. Great buy and dependable ratings at TIRE-RACK. Here is the problem:
I am still getting the LF tire is FLAT code on my display. I went out and drove it and still appears as a FLAT tire, which is false.
I disconnected the battery and nothing cleared. I also noticed that the FL is reading a pressure but my FR is not. Is there a way to turn it all off? A fuse maybe?
I am a guy that checks fluids weekly and tire pressure weekly too, so I have never depended on this read out anyway.
Also, I am looking to buy a couple of these tires for the rear, but TIRERACK is on back order, any other ideas?
Appreciate your help!
Micah
Old May 7, 2005 | 05:43 PM
army2000's Avatar
army2000
St. Jude Donor '11
Hey Squid, sounds like you might have some bad TPS or you need to reset the codes in your DIC. Good luck and welcome back.
Old May 7, 2005 | 08:11 PM
TJ VETT's Avatar
TJ VETT
saw your address and got homesick for Hawaii, I did 3 years there in the 80 s at Barbers Point. I had a 1976 vett while I was there and was paying about a buck a gallon for go juice, can only guess what your paying now. Good luck and enjoy your tour !!!!!
Old May 7, 2005 | 10:41 PM
bekdad's Avatar
bekdad
Using non-runflats, you might want to consider getting the tire pressure sensors working again. They will key you to a slow leak - well before your weekly check - and maybe save you a lot of grief.
Old May 9, 2005 | 07:38 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Yeah, it is nice (the weather), it is too busy out here now. The gas, well, when I left for deployment six months ago it was $2.30, got back a couple of days ago and it is $2.50. WOW!
Thanks Soldier, for your comment above.
If I don't find anything out soon about fixing this problem, I will go crazy. I am going to try my DIABLO Predator and see if that will clear it. Probably not, but I can have a tune written to get it cleared....I hope.
Take care,
Micah
Old May 9, 2005 | 01:11 PM
Try relearing the sensors - if that doesn't clear the message, you may have to get a dealer to clear it.
Old May 10, 2005 | 08:08 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
What do you mean by "relearing the sensors?"
I was thinking of just buying another one in a few weeks. LOL!
Thanks,
micah
Old May 10, 2005 | 08:55 AM
Sneaky Fast's Avatar
Sneaky Fast
Thanks,
micah
You can RE-LEARN the sensors but I can't remember how! Someone here will!! GOOD LUCK!! Oh and I believe a new sensor is quite pricey so I would try everything with the ones you have!! Maybe the tire place will pay for a new one if they broke it with the new tires!!!
OH and WELCOME BACK & THANKS FOR YOUR SERVICE!!!!!!!!!!!!!!!
Old Jun 14, 2005 | 02:48 PM
Ruler89's Avatar
Ruler89
https://www.corvetteforum.com/techti...D=77&TopicID=1
Old Aug 19, 2010 | 10:11 PM
wcdaniel's Avatar
wcdaniel
Not to hijack, but my '03 had a flat run-flat. I replaced the fronts with non-run-flats and according to the repair dude, they did what is called a TPMS Sensor Kit 'Rebuild' which were $4.5 each.
The problem is I cannot get the left front to react to my special BBS Magnet reprogramming tool nor a very strong general magnet. Ideas ??
To Flat Tire?
