Water pump trouble...
Old May 7, 2005 | 10:15 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
Default Water pump trouble...
Well, at 55,000 miles, it looks like my water pump needs to be replaced.
I started smelling coolant occasionally, but could never find a leak. A couple of months ago, I replaced coolant and hoses, but still found no defects in the hoses, coolant level was good, color was nice and bright (but still every once in a while, i'd get the smell).
Fast forward a couple of months. Pulled the car out this morning... there are 2 drops of coolant on the garage floor
So tonight, I rechecked everything, and now I have a nice leak
Question... Are there any differences between LS2 and LS1 waterpumps? Are they compatible? and is the LS2 pump any better?
Old May 8, 2005 | 05:47 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
dunno if there is a difference.....good news is it should be easy to replace
Old May 8, 2005 | 07:10 AM
Not sure of the difference between the two pumps, but good luck getting it fixed.
Old May 8, 2005 | 07:13 AM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Where did you find the leak on the engine Mazda? Can you describe it? Many water pumps have a "weep hole" that is the first indication of a leaky seal. I don't know if or where the weep hole is on an LS1.
Old May 8, 2005 | 08:13 AM
99C5Vert's Avatar
99C5Vert
The area is not visible. it drips on the crank pulley best I can tell.
Old May 8, 2005 | 08:15 AM
99C5Vert's Avatar
99C5Vert
I found this: http://www.ls1tech.com/forums/showth...ls2+water+pump
The LS2 pump is 3 lbs lighter, and has a lower profile. Now I just have to find out if there is only one style pump for the various models.
Old May 8, 2005 | 12:40 PM
JimAgain's Avatar
JimAgain
From that thread, it sounds like you're better off with the LS1 pump unless you really need the space.
The real question is; Is that a roundhouse kick that your cat is landing on your dog's face and do you have a larger photo of that? That is the greatest avatar
Old May 8, 2005 | 04:10 PM
99C5Vert's Avatar
99C5Vert
I'd say it's a jumping side kick
To Water pump trouble...
