Remote Control Range
Old May 8, 2005 | 03:59 PM
Charlie from Cherry Hill's Avatar
Default Remote Control Range
Recently I rented a 2005 Chevy Malibu with a remote control that worked from amazing distances. It had the remote start feature that actually worked from over 50 feet. I can't get the remotes on my 1999 FRC or 2003 Blazer to work from that distance. I've changed the batteries on all the remotes at least once, but that doesn't increase the range, certainly not even close to the Malibu's range. Are the newer GM remote systems capable of working at a longer range? Is there a way to increase the range?
Old May 8, 2005 | 04:16 PM
Vetten02's Avatar
Vetten02
I know this might sound stupid, but try putting your remote under your chin & pressing it. As hoakie as it sounds, it works for me.....
Old May 8, 2005 | 06:19 PM
Thanks, I have heard about that trick, but never tried it. I'm still puzzled by the range of this '05 Malibu's remote and wonder if GM is using a new receiver (or whatever it's called) in their later model cars.
Old May 8, 2005 | 06:24 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
I went into a sports complex a couple weeks ago and remembered after I was inside that I might have forgotten to lock my 2004. I went to the window of the building (I was on the second story overlooking a hockey field/court) to a place where I could see my car. The remote worked from there and I had to be at least 150 feet from the car.
Old May 9, 2005 | 11:51 AM
Default GM Upgraded the Remote Receiver in 2005
I had my Vette to the dealer for annual state inspection this morning and asked the tech about the 2005 Malibu's remote range. He told me that in 2005 GM has a new receiver in their cars with a much longer range for the remote. There's nothing wrong with my remotes, they're just the old technology.
Old May 9, 2005 | 11:57 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I have heard that the C6s have multiple receivers ( I think 5) so that the remotes work better. My 03 Grand Am's works best as I am sitting down in the recliner - pops the trunk or set off the alarm. Of course, if I am walking towards it to unlock the doors, it is finicky, but not as bad as the vette.
Old May 9, 2005 | 11:59 AM
jrose7004's Avatar
jrose7004
My Tahoes range is a good 50 feet or so but the Vette is maybe 10 feet! I know what you mean!
Old May 9, 2005 | 12:37 PM
I've also found that in addition to the shorter range for the remote, it can depend on what angle you approach the car from.
Old May 9, 2005 | 12:57 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
In was on the 12th floor of a building, my car was parked on the street about 1/2 block away and I could see it from the window. Just out of curiosity, I pushed the "lock" button and lo and behold, the back-up lights flashed. I was very surprised that it'd work from that far away...
On the other hand, you have to be standing practically right next to my wife's Buick Regal for the remote to work... Both GM cars. Go figure.
Old May 9, 2005 | 02:16 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Its funny
My Vette's FOB works no father than 10 feet. My Trailblazer's FOB works from hundreds of feet away.
Thats ok, I rather it not work so far away. So when my son get the remotes and pushes all the button, the vette will not unlock and stay unlocked.
Old May 9, 2005 | 02:26 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Strange but true................... this does work.
To Remote Control Range
