Car lowered..Going to reverse
Old May 9, 2005 | 02:35 AM
kg54trains's Avatar
kg54trains
Default Car lowered..Going to reverse
My car ia a 98 coupe that was purchased last August. After my "love in" with the purchase I now know this car has been lower and it must be to the max. I have issues with a driveway that has a incline and my air deflectors under the front by the cooling for the radiator scrap every time I bach down. What do I need to reverse to stock height? I also want to replace parts that might be cut or had been replaced to lower to max. If any one has this infor about the parts I want to change back to a stock height, replacement and proceedure to reverse slam I would appreciate a reply.
Thanks in Advance for the help.
Old May 9, 2005 | 02:51 AM
DaBoz's Avatar
DaBoz
We all deal with the scrapping... it's a $50 part. Replace it when worn out. But to tell the truth, once you've gone down.... you can never go back up. Lead in to the "Hotel California" begins playing in background.....
Old May 9, 2005 | 03:09 AM
gairno's Avatar
gairno
They look much better lowered. I say leave it the way it is.
Old May 9, 2005 | 03:13 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Change your angle of attack - approach at 45 or 90 degrees.
Never back out of a driveway.
Get Rocker Rails and Frame Savers.
Slam it - your Vette will thank you for it
EG
Old May 9, 2005 | 08:31 AM
EDJ's Avatar
EDJ
I also have mine lowered to the max on stock bolts and prefer it that way. If you want to raise it back it's simple to do. There is one bolt on the end of the composit spring on both the front and rear. To raise the rear end turn the bolt counterclockwise to raise the front turn the bolt clockwise. Just make sure you raise equally on all four corners. Some members suggest a four wheel alignment after raising or lowering. I have not noticed any unusal tire wear but it certainly wouldn't hurt to have the alignment done.
Old May 9, 2005 | 09:00 AM
jrose7004's Avatar
jrose7004
I have to back out of my driveways and be turning hard right not to scrape!
Old May 9, 2005 | 10:06 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
I have a 2002 with F-45 suspension and I am at least 1" lower than a friend of mine who has F-55 suspension. I haven't touched the suspension at all. So you may not be lowered. Just thought I'd mention it.
Old May 9, 2005 | 10:19 AM
baddvette98's Avatar
baddvette98
Leave it like it is. When you raise it back up and see how it looks you will put it right back down, on the ground!!
Old May 9, 2005 | 11:03 AM
99 vett babycar's Avatar
99 vett babycar
leave it alone - don't worry about the damage it's something everyone here knows you can afford. If you raise it you we know you won't like it because we won't think it's cool.
But if you insist do a search on "lowering" and just reverse the proceedure.
Old May 9, 2005 | 12:25 PM
Jeff Jeff's Avatar
Jeff Jeff
Sometimes when the rear is lowered, the person will cut the bushings and/or use longer bolts. Somtimes they will do the same on the front. I do not think it is possible to order the front bolt/bushings without getting a new spring, but I could be wrong. I believe you can get the rear bushings separate.
I am probably in the minority on the board. I had my car lowered as far as I could without cutting the bushings. The ride was rough (even with Bilstein shocks), but I got used to it. I recently raised it about an inch. The ride greatly improved, much less bumpy. It doesn't look as good, but I am glad I did it.
Old May 9, 2005 | 12:41 PM
0EG@EnglandGreen
Supporting Tuner
Did you get Bilstein Heavy Duty or Bilstein Sports? The Sports are valved to ride quite stiff - the Heavy Duty is about the same as the Z06 shocks, which is a pretty cushy ride (IMHO).
The Sports could be "uncomfortable" for some.
To the original poster : It's your car and you have to drive it. Do whatever works for you. We are not making the payments and we are not driving your car.
Good Luck!
EG
Old May 9, 2005 | 12:50 PM
ShaneN.'s Avatar
ShaneN.
what does it take to lower a vette?
Old May 9, 2005 | 12:52 PM
0EG@EnglandGreen
Supporting Tuner
about 15 minutes for the back and about 30 minutes for the front. It's free and you can do it yourself with very simple and common hand tools.
Old May 9, 2005 | 12:55 PM
yellow01's Avatar
yellow01
Only thing I'll add is that the Bilstein 'sports' are targetted to lowered cars With the HD you will run the risk of bottoming out on a lowered vehicle.
Old May 9, 2005 | 09:11 PM
NickP's Avatar
NickP
beautiful vette
To Car lowered..Going to reverse
