[Z06] Tire life
Old May 9, 2005 | 06:49 PM
WisconsinVETTE's Avatar
WisconsinVETTE
Senior Member
Cruise-In V Veteran
Default Tire life
I noticed yesterday that my right rear tire is worn quite a bit more than the left. Does the right spin more than the left when you get on the gass?
Old May 9, 2005 | 07:11 PM
barondw's Avatar
barondw
Yes
Old May 10, 2005 | 05:35 PM
Shylor's Avatar
Shylor
I don't think it should because it's posi traction.
Old May 10, 2005 | 05:50 PM
User 81424's Avatar
User 81424
Is the wear even?
Old May 12, 2005 | 06:11 PM
WisconsinVETTE
Senior Member
Cruise-In V Veteran
Yes its even across the tire.
Old May 12, 2005 | 06:16 PM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Air pressure even in both???
Old May 13, 2005 | 03:54 PM
WisconsinVETTE
Senior Member
Cruise-In V Veteran
yes it is
Old May 15, 2005 | 02:03 PM
Kenny94945's Avatar
Kenny94945
If it is wear even across the thread I say you are OK and there's nothing you can do.
If the center is wearing faster let a couple pounds out of the tire.
Old May 15, 2005 | 02:26 PM
User 81424's Avatar
User 81424
Can you quantify "quite a bit more"?
Old May 15, 2005 | 04:14 PM
anniv88's Avatar
anniv88
It's really a limited slip rear end so the right side will spin before
the left side does.
Old May 15, 2005 | 09:38 PM
Pumba's Avatar
Pumba
Joe,
I just had my differential upgraded with the DTE heavy-duty shafts, billet pinion bearing support, and Positraction pre-load springs. When we took the diff apart we found that one of the stock pre-load springs was broken.
The DTE springs add 33% more pre-load that the stock springs and this decreases the tendency of the right tire to spin before the posi locks up.
To Tire life
