Custom SUB BOX needed.
Old May 10, 2005 | 09:12 PM
gogo4's Avatar
gogo4
Default Custom SUB BOX needed.
Custom Sub Box ?!
Need 1 for 2x 12' Rockford Fosgate T1's
Anyone know a website where i can find 2x 12' box sealed pref. ?!?!
Or a good custom build shop here in the bay area?
Old May 10, 2005 | 09:54 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Here's a couple for you to try:
http://www.subthump.com/vette.htm
According to Patches, there's Lars Olufsen here in Atlanta that does some fantastic stuff. His forum handle is leolufse and he posts a lot in the Audio section. Check out some of his work. He is a talented guy.
You should also post this in the audio section. I think you'd get more responses.
Old May 10, 2005 | 10:22 PM
gogo4's Avatar
gogo4
yeah i need someone for 2x 12's! he only does boxes for 1....
Old May 10, 2005 | 10:29 PM
C5BlkVette's Avatar
C5BlkVette
St. Jude Donor '03 thru '08,'16,'18,'21-'22,'24
I've met Lars in person, he definitely has the talent to do quality work!! I know he sold his Vette and got a 350Z, but you can still find him at www.peachstateposse.com (GA Vette's website) once in awhile. Pretty good guy!
Andy
Old May 10, 2005 | 10:33 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
GOOD LUCK WITH TWO 12"s. A bit too much... In a sedan or SUV, OK, but a Vette??? Whatever.
Old May 10, 2005 | 10:35 PM
JACKAL0PE's Avatar
JACKAL0PE
Just tape 'em on the roof!
Old May 10, 2005 | 10:57 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
2 x 12's will not fit in the central storage bin. You would be best served with a bandpass box and just give up any idea of storage in the hatch area.
EG
p.s. Single RF Stage 2 12inch is more than enough, IMHO. Here's mine...
Old May 10, 2005 | 11:10 PM
EatRice's Avatar
EatRice
EG is correct. There is not enough airspace in the well for a proper 2 12 enclosure. You can use the air space in the well though and just build up from there if you really want to use 2 12's. Another option is a single 12 with alot of power to it. Also how custom do you want it? Where are you located?
EG...bandpass for a single 12 is going to run roughly the same size as an enclosure for 2 12's.
To Custom SUB BOX needed.
