Is the Vararam filter crap??
Whatever you do DON'T ask KORRECK
Bob
The foam filter is absolutely fine. It just doesn't look "technical" enough for some people.
As for the foam filter, I would like to see the oil analysis that indicates its fine. Until I see that, my K&N will stay where it is. I have asked this many times on this forum, no one has data to back up the foam filter is good theory. But on the air filter forum I belong to, foam filters do not provide good filtering, and if they do they are restrictive. Since this one is not restrictive, my guess is the filtering is no good. Have not seen proof otherwise yet.
Bob
Let me tell you about the Vararam filter. You would be better off using your wifes panty hose. And the K&N is better but still not very good.
The Vararam is a poorly designed air breather. It's resrictive to say the least. I have seen enough posts to be convinced there is a performance gain. How can that be if it's a poorly designed breather? It has to be the filter. Just remove your stock filter and run around with no filter. You'll have the same performance and the same protection for your engine.
I have been doing a little testing of my own. My ET's would vary by .25 dependent on engine temp. I am running a Blackwing, which is a superb filter. I determined that it was sucking too much air from the engine compartment.
I installed a Big Mouth air damn and cut a window under the Blackwing. Last weekend my car ran the same numbers over and over. Engine temp didn't make any difference. You can gain the same performance and protect your engine at the same time.
You can also see how we are closing the window for any water or debris from going up into your radiator.
Check it out at http://www.C4orceCorvette.com
Cold air???????
Is this the same man who told us?:
http://forums.corvetteforum.com/show...5&postcount=18
http://forums.corvetteforum.com/show...18&postcount=7
http://forums.corvetteforum.com/show...9&postcount=37
http://forums.corvetteforum.com/show...7&postcount=91
http://forums.corvetteforum.com/show...1&postcount=25
This man has now cut a hole into his radiator shroud to allow in what??????
Cooler air. Or "cold air" when looked at in comparison to the air that he was getting form where?????? Under the hood of his car.
Why??? I'll let him tell you
IATs perhaps???Very interesting in that he told us before that "sucking air from the engine compartment" was not hurting performance.
Installed a Big Mouth and cut a hole in the radiator shroud. The Big Mouth airdam now directs COOLER outside air STRAIGHT TO that Blackwing. Ingenius
C'mon. Tell us what you ran. Tell us how much of an improvement you got with your COLD AIR SYSTEM.
A cold air mod very similar to the one used by Dave68, except he uses a screen and does not have the Big Mouth Airdam.
And I wanna hear you say it........ COLD AIR WORKS
You are preaching to the choir my man
You are merely stating what we were trying to tell Bob all along.
Cold air???????
"I determined that it was sucking too much air from the engine compartment."
say that again:
one more time
Cooler air.
Will miracles ever cease???? I wonder just how he determined that.
You spend way too much time watching me.Now let me correct your errors. I am not getting 'cold air'. I'm getting what appears to be more ambient air vs hotter air from my engine compartment.
I never said you wouldn't lose performance sucking warm engine compartment air.
How did I determine that? I was not looking for any gains, just a solution to my inconsistansy problems related to engine temp. The solution was found by experimenting with my car.
As I've stated before, there is no such thing as cold air or ram air.
This would be a good change for you to make. And by the way, this is something I did myself. You do not need a Vararam and that junk filter on your car. Big Mouth is about $140. Window in the shroud is free.
I'm going to call it a night. Got to wash that Vette tomorrow. Washed the engine today. One of these days I'll get the Zaino out of the box.
Not ice cold, mind you. But certainly "colder" than what you were getting. So indeed you now have a modified "colder" air intake system. Congratulations
Bob, you are one funny guy.
On the one hand, I am glad to see that you are getting performance improvement, but on the other, it feels good to say......... I TOLD YOU SO
