First oil change
Old May 11, 2005 | 07:00 PM
utrico's Avatar
utrico
Default First oil change
I am going to do an oil change myself for the first time tomorrow. I am sure this has been talked about plenty. Can someone explain everything to me or point me in the right direction? I bought some rhino ramps and have plenty of Mobil 1. Do I change the oil filter at the same time? What else? Thanks
Old May 11, 2005 | 07:17 PM
YBNORML's Avatar
YBNORML
Raise the rear end about 3" higher than the front, use 6 1/2 qts of Mobile 1 5w30 and change the filter. Its a piece of cake. If you use a floor jack and jack stands, you can take your wheels off and give them a good cleaning also. Good Luck!!!
Old May 11, 2005 | 07:21 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Here you go, a step by step guide to changing your oil: with pics
http://www.spdkilz.com/techtipoil.html
POST 1000!!!
Old May 11, 2005 | 07:40 PM
utrico's Avatar
utrico
Thanks guys.
To First oil change
