fax me a copy of a z06 rear cooling duct template!!!went to whatever site's out there...nothing good.this is a need,need situation!hood going on on monday,and would like body shop to get these on at the same time.fax # is 518-792-9050.thanks.jesse
I've got the template at home as two documents. Just a thought though. Some fax machines do not do 100 percent size imaging; sometimes the image size changes. Be careful. You only get one shot at cutting into the rocker panels.
I agree, used the same documents. Print them without size adjustment and glue them on a cardboard. Works like a charme.
