Serpentine Belts
Old May 14, 2005 | 09:04 PM
MagRedSkull's Avatar
MagRedSkull
Default Serpentine Belts
What Goodyear Gatorback serpentine belts should I buy? I looked at Summit, but they list the Gatorback belts by length. What length or part number should I buy to replace both of my belts?
Old May 14, 2005 | 09:48 PM
2KFRC5's Avatar
2KFRC5
From the Goodyear site: 2000 Corvette
Goodyear GatorBacks
Poly-V Belts
4040420 Poly-V w/AC
4060798 Poly-V Alt & PS
http://www.goodyearbeltsandhose.com/...GSC5T:uur6d6ic
Old May 14, 2005 | 10:37 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Gatorbacks are noisy. stick with OEM.
Old May 14, 2005 | 10:57 PM
MagRedSkull
Goodyear GatorBacks
Poly-V Belts
4040420 Poly-V w/AC
Thanks for the info. Do you know if the listed part numbers will also work for a 2001? I tried the link, but it doesn't work. I had previously tried the Goodyear belts & hoses site, but it was no help in finding the correct belts and it had many broken links. I left the web site a message about how useless the site was for customers.
Old May 14, 2005 | 11:01 PM
MagRedSkull
Did you have a bad experience with Gatorback Poly-V belts on your Corvette? I have read threads on this forum that recommended the Gatorbacks to fix belt squealing problems.
Old May 14, 2005 | 11:28 PM
slicksilver11's Avatar
slicksilver11
I replaced serpentine belt with Gatorback and solved my squealing problem.
Old May 14, 2005 | 11:31 PM
2KFRC5's Avatar
2KFRC5
According to Goodyear, yes.
The link works for me. You have to enter your vehicle info. Start here. Click on "Select a product", and continue.
Old May 15, 2005 | 12:04 AM
MagRedSkull
Thanks for the help. I found my problem. The Goodyear site does not play well with the Camino web browser. When I went from Select a Product/Cars and Light Trucks I got a "error500". It worked fine when I switched to the Firefox web browser.
Old May 15, 2005 | 05:57 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
To Serpentine Belts
