2001 Question
Old May 16, 2005 | 01:03 PM
silverstreak01's Avatar
silverstreak01
Default 2001 Question
Looking to purchase a 2001 coupe with 13,123 mi. before I buy can anyone help with any info I may need to know about this model and year? ie: recalls, problems, things to look for. Hope this question is in the right place, I'm new to the forum. Thanks for your support.
Old May 16, 2005 | 01:14 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
http://corvetteactioncenter.com/spec...001/index.html
Good luck on the new ride
Old May 16, 2005 | 02:27 PM
viper8u2's Avatar
viper8u2
I asked the same thing about a month ago.
http://forums.corvetteforum.com/show...723&forum_id=1
Old May 16, 2005 | 02:41 PM
bierbelly's Avatar
bierbelly
Common problems:
Column lock
Differential leaks
High oil consumption
Rocking driver's seat
Whistling intake manifold
Intermittent fuel gauge
Some are beginning to report cracks in the thin spoked wheels at the connection to the outer rim.
Old May 16, 2005 | 02:47 PM
JLA's Avatar
JLA
Originally Posted by bierbelly
Common problems:
Column lock
Differential leaks
'01 Silver Coupe / OEM Chrome Wheels / Dual Power Seats / HID / A4 / 29K miles.....-0- problems
Old May 16, 2005 | 04:13 PM
BickyDhadwal's Avatar
BickyDhadwal
i have a 01 vert and the only problems i have at 61 thousand km are:
Column lock RECALL
High oil consumption (under warrenty)
enjoy your new car
Old May 16, 2005 | 05:08 PM
MisterC's Avatar
MisterC
My 01 has had a column lock recall and uses 1 pint of oil between oil changes which I do not consider high oil consumption.
To 2001 Question
