Hurst shifter fairly loose now.....
Old May 16, 2005 | 01:40 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Default Hurst shifter fairly loose now.....
I've only had it in for maybe 6 months now. It's pretty loose going up & down, but it's still stiff going right & left. Any suggestions or advice would be appreciated.
Thanks!
Ron
Old May 16, 2005 | 02:08 PM
champ53's Avatar
champ53
Which springs/spring combination do you have in it? You might want to try using the lighter springs. When I first installed my Hurst the side-to-side was so stiff, I ended up just using the softest spring in both sides.
Jules
Old May 16, 2005 | 02:28 PM
Dr.Ron's Avatar
Dr.Ron
Jules
I just used the springs that came installed on it.
Ron
Old May 16, 2005 | 02:48 PM
champ53's Avatar
champ53
Doc, why don’t you trying going with only the softest springs on each side. You should be able to get to the springs by just removing the boot.
Old May 16, 2005 | 08:42 PM
Dr.Ron's Avatar
Dr.Ron
I have no problem w/ the side to side stiffness. I'm curious about the softer up & down feel.....
Ron
Old May 16, 2005 | 08:57 PM
3318C5's Avatar
3318C5
Thanks!
Ron
Your original post says you have problems with the side to side movement. This can be resolved by switching to the softer springs that the shifter came with.
Old May 17, 2005 | 11:04 PM
Dr.Ron's Avatar
Dr.Ron
No, I mean it stiff side to side (in a good way), as it was up/down when I 1st installed it...
Ron
Old May 18, 2005 | 01:40 AM
Shylor's Avatar
Shylor
I'm confused. Do you mean forward and backward? Because side to side stiffness is controlled by the springs. This stiffness can be reduced with lighter springs or even removing one of the two springs on that side. If you are talking about forward and backward movement of the shifter, as in putting it in gear, there is nothing you can do about that. The shifter is just a lever, so this stiffness is the fault of your transmission. Or it may be possible that the **** on the bottom of the shifter, that goes into the shift linkage, needs greasing.
Old May 18, 2005 | 11:26 AM
Dr.Ron's Avatar
Dr.Ron
Sorry for any confusion. The side to side stiffer feeling, like when you're in neutral, I'm fine with.
When I 1st got the shifter it was similar to that while putting the car into any gear. That then decreased or I just got used to it.
Lately, since I've had a few strange things happen w/ my tranny, I've noticed that my into gear shifts seem a lot easier then I remembered...
If I grease the ***, wouldn't that just make it easier to shift?
Ron
Old May 18, 2005 | 05:38 PM
Shylor's Avatar
Shylor
I really doubt that is the problem but I guess you could try it. All that **** does is push the gear linkage forward or backward. It almost sounds like something in your trans is the problem.
To Hurst shifter fairly loose now.....
