red calipers
Old May 16, 2005 | 09:19 PM
doug doo wop's Avatar
doug doo wop
Default red calipers
Hi, who has the best deal on red calipers? Doug
Old May 16, 2005 | 09:22 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Rustoleum does.
Old May 16, 2005 | 09:24 PM
Z0SLIK's Avatar
Z0SLIK
Try Zip Products or Fred Beans!
Old May 16, 2005 | 09:53 PM
rickko's Avatar
rickko
Originally Posted by 84zz4vette
Rustoleum does.
Its easier to paint 'em yourself. You'll save a minimum of $394 plus the labor to install new calipers.
Its a tough choice though. Over $400 for calipers, shipping, & tax. Then labor to remove, replace and bleed brake system, say $200.
Or.....,$3.47 for Rustoleum paint at Home Depot. And a few bucks for a nice paint brush or foam brush.
I'm sure you'll make the correct decision that'll fit your lifestyle.
Have fun!
..rickko..
Old May 16, 2005 | 10:09 PM
v.vet's Z06's Avatar
v.vet's Z06
Rustoleum does.
Old May 16, 2005 | 10:21 PM
flyzlow's Avatar
flyzlow
Originally Posted by v.vet's C5
Home Depot
Old May 16, 2005 | 10:24 PM
srchief100's Avatar
srchief100
Rustoleum does.
That's funny........ but - that's exactly how I did mine based on advice from this Forum. And I am very happy with the results
Old May 16, 2005 | 10:32 PM
flyzlow's Avatar
flyzlow
I Watched it done last Friday on a new C6. Then used an exacto knife to remove the paint from the lettering. Looked great.
Old May 18, 2005 | 10:32 AM
rwlc5's Avatar
rwlc5
Doug,
I have enoufh Rustoleum left over from doing mine to paint a hundred calipers! You can borrow my paint, you just have toget your own foam brush.
Old May 18, 2005 | 10:55 AM
MTurnbo's Avatar
MTurnbo
I'm sure there is a thread on this somewhere but I may as well jump in here and ask my question. Do you break the brake line to do the Rustoleum paint job, meaning, does the caliper have to be completely removed from the vehicle?
Old May 18, 2005 | 10:58 AM
2K1 6T8's Avatar
2K1 6T8
Originally Posted by MTurnbo
I'm sure there is a thread on this somewhere but I may as well jump in here and ask my question. Do you break the brake line to do the Rustoleum paint job meaning, does the caliper have to be completely removed from the vehicle?
You can, but it is not necessary.
I didn't and they turned out great. Just tape off what you dont want to get paint on. Take your time as this is the most important part of the whole process.
And to remove the paint from the lettering, someone suggested an exacto knife. I am sure that would work, but I simply used some "Goof Off" on a rag and removed the paint that way.
Old May 18, 2005 | 01:11 PM
Just buy the paint and do it yourself. I went with Folia Tec paint and total cost was about $50. Sure beats paying better than $300 for the same calipers you have on the car now, only red.
Old May 18, 2005 | 02:43 PM
SGT. PYLE's Avatar
SGT. PYLE
Red Powder Coated ZO6 Calipers at www.gmpartsdirect.com
GM PART # 88895128
CATEGORY: Wheel Brake Cylinder/Caliper
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $177.52
OUR PRICE: $88.77
DESCRIPTION: Z06 LEFT FRONT CALIPER
Z06 Brake Calipers For added distinction, the wheels of the Z06 are designed to show off eye-catching Torch Red brake calipers - at rest and especially in motion.
GM PART # 88895131
GM LIST: $129.22
OUR PRICE: $64.62
DESCRIPTION: RIGHT REAR CALIPER
Old May 23, 2005 | 08:49 AM
c5_droptop's Avatar
c5_droptop
Cruise-In IX Veteran
A quick question on the painting. Everyone talks about taking the paint off the lettering with either an exacto knife, sandpaper, or paint remover of some sort to get back to the "metal look".
I have a pewter vert and am planning on painting mine shortly (planning on black). I realize that the paint is a high temperature paint, but was wondering if I could use body paint for the letters. What would happen if this paint was not the same high-temp stuff? I assume that it will eventually flake off, but I am looking at using it more for show purposes. Would it potentially damage the wheels (magnesium)?
Also, someone has mentioned applying some sort of a clear coat. Anyone have experience with this?
Thanks,
Dave
Old May 23, 2005 | 11:27 AM
maxfli's5's Avatar
maxfli's5
if you aint racin you want get that hot
Old May 23, 2005 | 12:26 PM
rwlc5's Avatar
rwlc5
As stated earlier, I painted mine with Rustoleum using a foam brush. Did the calipers red and then using the edge of a foam brush by lightly passing it over the letters, I did those in black. It's been 2 years and none of the paint has flaked off.
Old May 23, 2005 | 02:02 PM
Autoworker's Avatar
Autoworker
Rustoleum does.
Clean 'em real good with brake cleaner and a rag. You wont need a big can of Rustoleum, buy the small one. I went to the hobby store and bought a camel hair type brush.(more paint control) For the letters I used a Testors silver paint pen..... worked great! P.S. It took 2 coats of paint per caliper to get good coverage.
To red calipers
Old May 23, 2005 | 03:57 PM
love my car's Avatar
love my car
Paint Them 8 Bucks
Old May 23, 2005 | 04:12 PM
CUlookin's Avatar
CUlookin
Originally Posted by love my car
Paint Them 8 Bucks
got mine from Fred Beans... they're great!
Old May 23, 2005 | 10:00 PM
zipduda's Avatar
zipduda
I used a Q-tip in white fast dry paint and dab on the raised letters, two coats worked out fine.
