CD Player...is this normal?
May 17, 2005 | 09:18 PM
I have the stock radio with CD and when I hit a bump the cd will skip. Never had this happen in any other car. Anyone else have this?
May 17, 2005 | 09:21 PM
Quote:
Never had this with the head unit, only if I was playing a disc in the rear changer.
May 17, 2005 | 10:37 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I've not had that problem in my two years with the Vette.
May 17, 2005 | 10:42 PM
If your player has had a lot of use the laser could be getting weak .
May 17, 2005 | 10:47 PM
Try running a CD lens cleaner. The lens might just be dirty and not reading the disc correctly all the time. At least this is a cheap thing to try to solve your problem.
May 18, 2005 | 03:04 AM
Had that happen for the first time the other day...I have the changer in the back (no head unit). My guess is that the CD is flawed though.
May 18, 2005 | 06:24 AM
Mine doesn't skip when hitting a bump.
May 18, 2005 | 07:02 AM
I have a disc changer in the trunk, and it happens to me if I hit a bump.It has been doing that from the day I bought it. No damage to the cds.
May 18, 2005 | 07:23 AM
Happens quite often to my car as well, I was just thinking about upgrading the head unit
May 18, 2005 | 07:27 AM
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
May 18, 2005 | 07:50 AM
No problem here, I try to avoid bumps.
May 18, 2005 | 08:17 AM
Only on my rear changer & only when a "shock" (severe bump) occurs.
May 18, 2005 | 08:22 AM
Haven't had it happen yet and I've had two different Vettes with the 12 disc changer. <crossed fingers>
May 18, 2005 | 08:39 AM
Normal (SNAFU).
May 18, 2005 | 08:44 AM
St. Jude Donor '05, '12-'13, '15-'16, '21
Nope....not with the head unit.
May 18, 2005 | 06:57 PM
Thanks for all the replies. I bought a new cd to see what would happen and it was fine! Guess it is just that some of my old cd's are worn out.
May 18, 2005 | 09:08 PM
St. Jude Donor '12-'13-'14
Im CD stacker is in the rear, and it happens every time I hit a bump.
May 18, 2005 | 09:24 PM
St. Jude Donor '03-'04-'05
Quote:
May 18, 2005 | 10:53 PM
Quote:
Same here. My changer was just installed about two weeks ago and skips when I hit jarring bumps. I wanted the unit installed in the right rearmost hatch storage compartment, not the larger middle one. They said it might skip more often there because it's closer to the wheel-well. The skipping doesn't really bother me (it's not constant) and the disc picks up playing again at the spot it left off.
May 19, 2005 | 02:17 AM
Same dealy for me... skipped every time I hit a bump... finally had the AUX changed to play my iPod.
