rocking seating problem
Old May 17, 2005 | 09:31 PM
98droptop's Avatar
98droptop
Default rocking seating problem
Did anyone ever come out with a kit to fix this problem? I have read a couple threads on it and it appears to be a pain in the @#$. If you buy a replacement track for the power seats does that solve it? Probably the most expensive solution.
Any ideas from those that have dealt with it.
98droptop
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
i have it and hate it.. so a for u and me!
Old May 17, 2005 | 10:11 PM
DAYCRZ's Avatar
DAYCRZ
Default rocking
I had it too on my 01 but was able to have it fixed under warrenty,the dealer invoice said "replaced seat adjuster" or something to that effect
do a search on rocking seats in the help section' I remember seeing a post on fixing your problem
Dan
Old May 17, 2005 | 11:00 PM
MADDOG97's Avatar
MADDOG97
I feel the same. Mine dose it but the "how to's" seem like a real pain in the butt.
I looked and a new seat track is about $700.00
Old May 17, 2005 | 11:56 PM
NitrousMan's Avatar
NitrousMan
Dan
So they will cover it under GMPP warranty? My 02 is starting to do it now. I've been waiting until I have a few things that need to be fixed under warranty so I can get as much fixed for the 100.00 deductible at one time.
Old May 18, 2005 | 12:01 AM
not08crmanymore's Avatar
not08crmanymore
Default gmpp
yes they will!wanted to have mine done,but the warranty ran out while car was still stored for winter..i.e.tons of snow on the ground!oh well...
Old May 18, 2005 | 12:06 AM
jrose7004's Avatar
jrose7004
TTT!
Old May 18, 2005 | 12:15 AM
NitrousMan's Avatar
NitrousMan
Sweet...Thanks.
Old May 18, 2005 | 04:33 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Oh cool! I haven't seen a thread on rocking seats for a couple of months.
Wanna know how to fix them?
Here ya go!
http://robbs.js-x.com/ken/vette1/
BTW, Easy job Nylon spacers
3/4 od X 7/16 id X 13/64 (.203) thick. Pick the spacers up at a home center. Open it up from 3/8.
Old May 18, 2005 | 07:26 AM
2K1 6T8's Avatar
2K1 6T8
It's really not that hard.......
Follow the instructions carefully and do it!!!
Old May 18, 2005 | 07:29 AM
sandmanusd's Avatar
sandmanusd
I actually don't mind the seat rocking "problem"... sorta makes you feel the acceleration better... makes your seat "fly" back when you take off fast...
Old May 18, 2005 | 08:50 AM
MADDOG97's Avatar
MADDOG97
Yes it does, but try this. get into your car in work parking lot, put in reverse, push gas a little to hard......seat slides FORWARD mashing down gas pedal very very bad
Old May 18, 2005 | 09:00 AM
molson's Avatar
molson
It's a very easy fix....
You don't have to take the tracks off your seat or remove those little plastic *****.
First side took about an hour...second took 10 min.If you have any questions,I would be glad to answer.
Old May 18, 2005 | 09:15 AM
MadRick's Avatar
MadRick
molson,
I need to fix my 97 rocking seat...do you have any written instructions on your easy fix??
Thanks in advance!!!
Old May 18, 2005 | 10:15 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
See Jackalope's post above. Great instructions with pics.
Old May 18, 2005 | 10:20 AM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Details here would be good.
Old May 20, 2005 | 08:28 PM
George8211's Avatar
George8211
Just pulled the driver seat out to fix mine. Thanks for the tip on not removing the frame from the seat. I only need to do one of the tracks. I was hoping for a short cut.
To rocking seating problem
Old May 20, 2005 | 08:43 PM
98vert6spd's Avatar
98vert6spd
THE guide on how to fix it leaves a few very big issues out
first off to actually get the damntrack off the seat is not easy
the bolts are in a manner such that no tool fits on them
at least thats how it was on my 98
i can fix both seats for 250 if anyone wants me to
and youll never have to worry about it again
for some reason chevy used rubber where they should have used metal
if you want to try it yourself id be happy to explain it if anyone has any questions
id also be interested to know how you can fix it without taking out the white ***** cause they are an absolute pain in the sak to deal with
im in ohio
Old May 20, 2005 | 08:48 PM
Maniac's Avatar
Maniac
Old May 20, 2005 | 09:04 PM
DADEO's Avatar
DADEO
My 99 rocks also. Sure would like your easy fix instructions.
